Author Topic: Water test  (Read 4338 times)
5050racing
  • OWF Brand: CB-1450
Water test
« on: November 01, 2014, 05:54:21 PM »
Haven't seen much on people testing it but u better!! Just did mine and keep a log hopefully never need to show it  but it may help warranty ??? Mine is 8.5 ph and 25 drops of nitrite to make it pink for at least 1 min.just a reminder to everyone
Re: Water test
« Reply #1 on: November 02, 2014, 02:27:53 AM »
5050racing - Great point.  I'm waiting for my corrosion inhibitor to arrive.  I needed to add a bit of water due to fitting that was leaking and it took a bit of water from the OWB thus, the reason for topping it off.  I tested with the kit my CB dealer provided me nearly 4 years ago it would not turn pink even when over 40 drops were placed in the water.  I called my CB dealer it indeed does have a shelf life.  If the dark bottle contents has turned to a more of a brownish color instead of the purple color, it's gone bad and you'll need a new bottle.  I test with my water with the new it hit only 15 drops and I want it at 20 to 30.  So, keep an eye on the color of the purple stuff, it can go bad.  I'm hopeful the corrosion inhibitor will arrive early this week.  Roger
5050racing
Re: Water test
« Reply #2 on: November 02, 2014, 03:59:13 AM »
 Thanks for that info also,like pool chemicals,did u ever have to raise the ph and if so what did u use ? Like a pool I will ask dealer also
Re: Water test
« Reply #3 on: November 02, 2014, 04:34:13 AM »
I've never had to adjust the ph in the water.  I really wouldn't know what to use if I had to raise it.  I guess the dealer is the best resource.  Roger
