Author Topic: problems using 500 gal. propane tank  (Read 18470 times)
vpd66
Re: problems using 500 gal. propane tank
« Reply #15 on: November 05, 2014, 07:58:48 AM »
First off patching a leaky boiler is a job I would avoid. Chances are if it is leaking in one spot it is ready to start leaking in another. Its a blind repair. You can't see the side thats rusted and the side your welding on is very contaminated with ash,soot, and creocote. Every welder I know that has patched a boiler have always stick welded it. I believe a 6010 rod is preferred has it is good on dirty steel. The magnifier lens work good. Several guys I work with use them.
