Pages: 1 2 [3]
Author Topic: Burn Time  (Read 24877 times)
Maxnchej
  • OWF Brand: Portage and main
  • OWF Model: Bl2840
Re: Burn Time
« Reply #30 on: January 10, 2015, 08:55:30 PM »
I'm not getting that long of a burn since it has gotten that cold. What type of wood are you using? How high do you lids the stove?
Jwood
  • OWF Brand: P&M Ultimizer
  • OWF Model: Bl 28-40
Re: Burn Time
« Reply #31 on: January 10, 2015, 10:46:20 PM »
Burn mixed hardwoods birch oak maple and ash and when its in the teens I fill it half full and when its -15 I fill it full
North Central Minnesota
Stihl MS 270c
Stihl MS 461
Blacked out Fiskars X27
06' Silverado 2500HD Duramax
Uponthehill
  • OWF Model: 250 & 461 Stihl
Re: Burn Time
« Reply #32 on: January 15, 2015, 04:18:10 AM »
Max,  I think your burn times may be affected by a possible brick that has fallen over in your 2840.
Maxnchej
  • OWF Model: Bl2840
Re: Burn Time
« Reply #33 on: January 16, 2015, 04:59:05 PM »
How do you check if you have the issue? Do you need to empty completely and then what are you looking for? Really don't want to shut off until spring if I can help it
Re: Burn Time
« Reply #34 on: January 16, 2015, 05:17:32 PM »
A lot of questions can be answered by simply monitoring water temps, Heat loss can be in pipe, low flow, larger heat load than expected, too much draft, poor wood, sticking air dampers, you get the picture we need to have much more information. If it is an issue with the stove and or bricks you will have reduced air flow and the fire will not burn properly, is that the case ?
Pages: 1 2 [3]
