Author Topic: ridgewood 6000 review so far.  (Read 12455 times)
fsuftball
  • OWF Brand: ridgewood
« on: November 21, 2014, 07:03:49 AM »
Been burning since 9-24-14 and its finally got down into low teens last night 3 degrees when i got up at 5am. the stove was on 9 hours of burn time heating my 2500 sqft house 1500 main 1000 basemenet. still have some logs in it and my house was set to 71 last night and my DHW, these stoves are great. i have 14-15 cords stacked and i sure hope that is enough. my guess is around 1 cord a month(or at least i hope). i havent burned 1 cord yet maybe 3/4 cord but its been warmer.
r-19 in the walls ( we are doing new windows siding and spray foam in the spring)
Added 10 inches to my attic so i have around r-50-5-60 in attic(this helped a ton i only had r-20 last winter.
anyways i am burning the last of my poplar with a mix of a few cherry pieces, my wife loads it during the week when i am gone we couldnt be happier with this stove and the temp of our house.
total investmenet is around 5100-5500
thanks craig.
automan77
  • Just say no to propane
Re: ridgewood 6000 review so far.
« Reply #1 on: November 21, 2014, 07:21:53 AM »
Best investment I have made in a long time.
Scott K
Stihl ms 311
Husky 455
St Clair County Michigan
Troy Built 27 ton splitter
free heat
« Reply #2 on: November 21, 2014, 02:04:39 PM »
Same here, going on my second season. I figure around a face cord per week in Wisconsin. These stoves are great work horses couldn't be happier with mine. Most days with hickory or oak I can stretch 18 hours easy heating dhw and 2800 sq ft in Wisconsin.
Ridgewood 6000
Stihl 039, 290
Fiskars x27
golffanman
« Reply #3 on: November 22, 2014, 09:25:46 AM »
I'm on my second year as well. I upgraded my chimney and now it is 8 ft. Made a big difference in draft. It got us through a horrible winter last year and this year is starting out bad as well. So far my stove is running fine.
Huskee 22 Ton Splitter
Husqvarna 450 Chainsaw
fsuftball
« Reply #4 on: November 22, 2014, 09:52:17 AM »
I have an 8 foot stack as well.
What was it doing without it? You have a better burn with it?
jamesbodeis
  • OWF Model: 7500
« Reply #5 on: November 23, 2014, 07:12:27 AM »
Curious about the stack also. Did it increase your wood consumption, how much faster were your recovery times.
Ridgewood 7500
The thumb of michigan.
Jonsered 2260
Roscoe
  • OWF Brand: Hawken
  • OWF Model: HE2100
  • Southeast Michigan
« Reply #6 on: November 24, 2014, 05:54:22 PM »
Yeah, tell us about the pros and cons of extending the stack.
JD 7775
Kioti DK35
Bobcat S250
All Wood Oak Series
Stihl 036pro, 362c, 064
Husk 385,570
Shindiawa 416
Griffin 14' Dump
golffanman
« Reply #7 on: November 25, 2014, 07:06:02 AM »
So far I have found no cons with the longer stack. The stove is burning completely different from last year. When the damper door opens, the fire is more intense. I'm not filling the the stove completely right now, my fire is in the center of the stove. I also noticed a more complete burn of the wood. Hope that helps. Forgot to add.....last year my stack was 4ft and was just the cheap sheet metal pipe from Menards. Now it's 8ft and it is the heavy schedule 40 from Ridgewood.
« Last Edit: November 25, 2014, 07:55:13 AM by golffanman »
automan77
« Reply #8 on: November 25, 2014, 08:06:21 AM »
Mine seems to burn fine with my 3 ft stack. No complaints.
Scott K
Stihl ms 311
Husky 455
fsuftball
« Reply #9 on: December 05, 2014, 12:32:00 PM »
Stove wasn't heating up as fast as usual so i finally removed some ash, had a wheel barrel full out the front half of the stove(hot coals i pushed back to clean it) Brought the hot ash and wood upfront and boom temps started to rise.
its been 8 weeks since i started it up mostly poplar since its hasn't been to cold besides that one week in the single digits.
Dont forget to clean out those boilers!
just bought a new fixars 36 inch ax and i have been splitting 23 inch round ash with ease, its faster and easier than my wood splitter. did 1 cord in an  hour with splitting it small for my wife
automan77
« Reply #10 on: December 06, 2014, 08:17:08 AM »
I'll take out a  five gallon bucket of ash every couple weeks.
Scott K
Stihl ms 311
Husky 455
Roscoe
  • OWF Brand: Hawken
  • OWF Model: HE2100
« Reply #11 on: December 06, 2014, 03:11:46 PM »
I added a 3ft section of chimney on my 7500. Looks just like automan77's set up. It made a huge difference in my draft. Hotter fire......faster recovery time. Highly recommended.
JD 7775
Kioti DK35
Bobcat S250
All Wood Oak Series
Husk 385,570
Shindiawa 416
Griffin 14' Dump
jamesbodeis
  • OWF Model: 7500
« Reply #12 on: December 06, 2014, 03:14:41 PM »
I've got 6 feet on mine now. Much better recovery times.
Ridgewood 7500
Jonsered 2260
