Author Topic: Addition  (Read 6730 times)
Addition
« on: November 30, 2014, 02:44:43 PM »
So I am planning a heated mud room for the summer. I will need to put it on sauna tubes because of rocks as foundation in this area. I would like to install radiant heat in concrete, not shure if I can without the extra cost of someone to pump it. Anyone use something similar to war Board? How do you like it?  Radiant in the walls?
atvalaska
  • OWF Brand: aqua-therm
  • OWF Model: coal one 275
  • 907, no vacancy !
Re: Addition
« Reply #1 on: December 01, 2014, 10:38:01 AM »
use warm board   my whole house is warm board ,if yours  will be in  a crawl space/ open to the outside  do this.....      ( I have r40 + rim joist/ 2x8 walls)   I took the stupid reflextix/astro foil ( the ONLY use for this stuff PERIOD) stapled it to the under side of the BCI's/ I joists ,leaving the 1.5 space open >> then spray foam it  ... the pic I posted is of my rim joists ...I rolled out the foil stuff then on the ends, I rolled it back in on itself 1' from outside wall  then sealed it with foam ...u could do same then spray the foil with foam ...... .02 cents > although these guys sure liked what I did  http://www.cchrc.org/
« Last Edit: December 01, 2014, 10:45:00 AM by atvalaska »
Re: Addition
« Reply #2 on: December 01, 2014, 11:12:41 AM »
what is a "BCI" atvalaska?  Not sure of the acronymn.  Thanks  :thumbup:
atvalaska
  • 907, no vacancy !
Re: Addition
« Reply #3 on: December 01, 2014, 02:01:33 PM »
I joist ...I have the "top of the line" ones> series 90 ,16"   > http://www.bc.com/wood/ewp/simpleFraming/bciJoist.html
Re: Addition
« Reply #4 on: December 01, 2014, 02:13:06 PM »
Pipes in concrete, CAN NOT be run with 180f boiler water, you have to mix down.
I prefer to put pipes in concrete, because it is really hard to retro fit and put the pipes in later  ::) but thats just my opinion
Re: Addition
« Reply #5 on: December 01, 2014, 04:19:32 PM »
No problem mixing down, think I amgoing to try radiant walls too.
atvalaska
  • 907, no vacancy !
Re: Addition
« Reply #7 on: December 02, 2014, 09:58:39 AM »
OK gald to hear you have no issues mixing down, just wanted to help make sure you had all the information you needed before you pulled the trigger
Cabo
  • OWF Brand: P & M
Re: Addition
« Reply #8 on: December 02, 2014, 05:14:08 PM »
Coolidge,
Something you may want to look into is called Smart Trac by Watts.  I will be using this system on an upcoming project.  The thing that impressed me with this system over others I have installed is that you don't need to cover the PEX with metal/flashing so as you put down your finished floor you can see the PEX.  Should save time in marking/measuring to avoid hitting something.
Re: Addition
« Reply #9 on: December 02, 2014, 06:13:15 PM »
Cabo,   I have seen that system before somewhere, actually forgot about it. Thanks
