Author Topic: Unit heater  (Read 10182 times)
wissel12
  • OWF Model: 7500
Unit heater
« on: December 04, 2014, 07:40:50 AM »
I installed a unit heater in my garage. My house has three zones of hot water heat.  I was not using my basement zone. So I hook into that zone for the unit heater in my garage.
My problem is that the T stat in the garage tells the pump to circulate and to open the zone.  So that leaves the motor on the unit heater. I bought a snap disc, thinking that would do the trick strap to the cooper line.  It will not close it unless I take a torch to the snap disc.
Is there any simple relays I can use to operator the fan?
03 Duramax 72000 Miles
Massey Ferguson 275
WD 45
OC4
Stihl Farm boss 290
Stihl 025
Strasburg, Ohio
Re: Unit heater
« Reply #1 on: December 04, 2014, 07:50:36 AM »
A Honeywell strap on Aqua Stat is the simplest way I know of to control the fan motor!
wissel12
  • OWF Model: 7500
Re: Unit heater
« Reply #2 on: December 04, 2014, 07:57:12 AM »
So when the copper line heats ups, it will tell the fan to run.
That would work, just looking for something cheaper.
Massey Ferguson 275
WD 45
OC4
Stihl Farm boss 290
Stihl 025
Strasburg, Ohio
Re: Unit heater
« Reply #3 on: December 04, 2014, 07:59:07 AM »
The ones I use are just over $100
wissel12
  • OWF Model: 7500
Re: Unit heater
« Reply #4 on: December 04, 2014, 08:00:36 AM »
How about this: Grundfos 595656 1/2-Inch Clip-On Aquastat Control. Just found it on amazon.
Massey Ferguson 275
WD 45
OC4
Stihl Farm boss 290
Stihl 025
Strasburg, Ohio
wissel12
  • OWF Model: 7500
Re: Unit heater
« Reply #5 on: December 04, 2014, 08:05:18 AM »
Never mine that is backwards from what i need
Massey Ferguson 275
WD 45
OC4
Stihl Farm boss 290
Stihl 025
Strasburg, Ohio
Re: Unit heater
« Reply #6 on: December 04, 2014, 11:10:02 PM »
Just run the power to the unit heater off the same source as the pump. Then they will come on together.
wissel12
  • OWF Model: 7500
Re: Unit heater
« Reply #7 on: December 05, 2014, 09:20:28 AM »
I can not do that, because when a different zone would energize the fan would run.
Massey Ferguson 275
WD 45
OC4
Stihl Farm boss 290
Stihl 025
Strasburg, Ohio
atvalaska
  • OWF Brand: aqua-therm
  • OWF Model: coal one 275
  • 907, no vacancy !
Re: Unit heater
« Reply #8 on: December 05, 2014, 10:06:04 AM »
my snap dick work the same ...they want 100% contact ...I just got one with a "lower come on temp"...i'll see this weekend.
wissel12
  • OWF Model: 7500
Re: Unit heater
« Reply #9 on: December 08, 2014, 05:15:23 AM »
The lowest I could find was 110 turn on temp.  Where did you mount yours?
Massey Ferguson 275
WD 45
OC4
Stihl Farm boss 290
Stihl 025
Strasburg, Ohio
atvalaska
  • 907, no vacancy !
Re: Unit heater
« Reply #10 on: December 18, 2014, 02:26:22 PM »
Never got to it yet :(
wissel12
  • OWF Model: 7500
Re: Unit heater
« Reply #11 on: December 22, 2014, 05:18:12 AM »
I talk to a hvac person and they said to use a 24 volt relay off the thermostat.
Massey Ferguson 275
WD 45
OC4
Stihl Farm boss 290
Stihl 025
Strasburg, Ohio
wissel12
  • OWF Model: 7500
Re: Unit heater
« Reply #12 on: February 14, 2015, 09:15:28 AM »
Well slim, I ended up putting a aquastat on the unit heater. Set it @ 120. Working good.  Thanks
Massey Ferguson 275
WD 45
OC4
Stihl Farm boss 290
Stihl 025
Strasburg, Ohio
Re: Unit heater
« Reply #13 on: February 14, 2015, 10:35:42 AM »
Awesome, glad I could help!
