Author Topic: DHW Question  (Read 8354 times)
ST98
DHW Question
« on: December 06, 2014, 05:56:05 AM »
After reading the different takes on DHW I'm going with a plate exchanger before my electric water heater. I don't plan on running my furnace more than the seven months I need it. When I shut down would I just continue to run my cold water feed through the exchanger or do I install a bypass with a couple of valves?
Re: DHW Question
« Reply #1 on: December 06, 2014, 06:14:13 AM »
You could run water thru it year round I suppose, but it would also scale up faster depending on your water quality.
Re: DHW Question
« Reply #2 on: December 06, 2014, 12:00:15 PM »
Unless the cold water feed is running through a water softener first.  ;) :thumbup:
lindnova
  • OWF Brand: Heatmor
  • OWF Model: 200 CSS
Re: DHW Question
« Reply #3 on: December 09, 2014, 11:21:35 AM »
I have a bypass on mine.  I switch it in summer.  After not installing bypasses the first time, I have put them in as I modify the system.  That way if it leaks or needs to be de-scaled, I can continue to use hot water with the lp tank.
Stihl ms260, ms362, msS461
Huskee 22 TN Splitter
Kubota BX2200 w/ Loader
Re: DHW Question
« Reply #4 on: December 13, 2014, 09:33:30 PM »
Thinks can still crud up even with a softener, seems more people don't have soft water than do.
