Author Topic: When to Remove Ash.. Has Been Discussed before would like to revist the topic  (Read 11546 times)
intensedrive
  • OWF Brand: Ridgewood
  • OWF Model: 6000
Hi,
I have a few posts under my belt but rather new, second year running a outdoor boiler.  I believe from reading previous posts that I might removing the ash too frequently.  I usually take 5-6 shovels full every 4 days.  When I shovel the ash I tend to shake the shovel a bit to allow the larger coals to drop off, and try to get the finer ash into my metal barrel.  No matter how hard I try it seems the ash is extremely hot and causes the 55 gallon drum to heat up extremely fast.  Today I realized after all this time that I'm shoveling out ash that would be heating my house.  I tend to get very anal with the ash removal now rethinking that I should let the ash stay in the box longer.  My fear was the ash acts a insulator not allowing the heat transfer to the water.  Every morning I rake ash and the pile to the front and load the wood on top and to the back.  Is there a trick to get just the ash and not the hot ash with hot embers?
fsuftball
  • OWF Brand: ridgewood
  • OWF Model: 6000
I just removed the ash for the first time after 8 weeks of burning, I removed a wheel barrel full.
I waited till it needed to be loaded and my water temp was down to 160, pushed all the hot coals to the back, took a shovel and rake and brought them outside.
 Your are removing to much to soon. Wait 4 weeks at least.
I have a ridgewood so I'm not sure how the dual fuel models work if that's what you have.
Chas
  • OWF Model: 6000
I take out a partial wheelbarrow load about every 2 weeks or so. I try to take as much ash as possible but am not real concerned if I get some coals too.
Dolmar 035
Stihl 026
Stihl 260
Speeco 25 ton splitter
John Deere 4720
Polaris Ranger 800
Middle of the mitten, Michigan
fryedaddy
  • OWF Model: 750 Gallon
Buy a metal rake and use it to seperate the coal and ash.
atvalaska
  • OWF Brand: aqua-therm
  • OWF Model: coal one 275
  • 907, no vacancy !
I crank my auger ..and remove a bit less than a large steamer pan every 7 days = better air flow under the grates...I forgot 1 week and had ash rite to the bottom of the grates/made for a hard to burn fire to boot!
CountryBoyJohn
  • OWF Model: MF 10,000 E
I have a metal trash can I transfer my ash into.  After it cools, i load to a wheel barrow and dump it.
2013 F250 6.2L Lariat
Stihl MS290
DHT 27 Ton Log Splitter
Woodchuck Log Jack
56, 57, 58 Ferguson TO-35
Knox County, IN
ST98
I'm thinking around Jan 1st which will give me about three months. Then one more time before May shutdown.
intensedrive
  • OWF Model: 6000
How much wood do you burn in season?
ST98
Last year it was about 18 cords, not face cords. Hopefully this year no more than 15.  It's a tractor bucket when I clean out.  It's a CB6048 so it has alot of room.
fryedaddy
I normally use a rake and push everything to the back then rake the coals forward.
I can pull a wash pan worth of ashed every two weeks.
I like to keep mine fairly clean but nothing is perfect
yotehunter66
  • OWF Brand: Woodmaster
  • OWF Model: 4400
A bucket full about every two days. My stove has an auger so I only get ash.
Husky 372xp 24"
Makita DCS520i 20"
Poulan 2300 18"
Troybilt 27 ton log splitter
fireboss
  • OWF Brand: central boiler
  • OWF Model: 6048
I take a few small shovels out every few days or so  I think the ash acts like an insulator  and the heat doesn't transfer
sabercat
  • OWF Model: 5036
seems like every few days we are taking a 1/4 wheelbarrow out, CB 5036, natural draft. My old stove was fan forced air, which I only took ashes out a couple times a season. I figured being force draft it was blowing the fines up the chimney. But it seems we are taking out too frequently, I've been burning with a OWB since 2000. Burning 100% white/scrub oak.
fryedaddy
Ash does act like an insulator.
My stove has a very small amount of water beneath the firebox due to this.
