Author Topic: Sulfur smell  (Read 10438 times)
Shrek1112
  • OWF Brand: Hawken Energy
  • OWF Model: HE-2100
Sulfur smell
« on: December 21, 2014, 08:24:11 PM »
I recently had a Hawken HE-2100 installed with DHW plate exchanger on the outlet side of my water heater.  I have turned the water heater to pilot mode to save more on propane but we have recently noticed the strong sulfer/rotten egg smell when using hot water. I have read many articles that point to an anode issue in the water heater but it seems odd that it would happen right after our boiler was up and running. Any suggestions would be appreciated.
Mid- Michigan (Spartan Country)
Stihl MS-250
Stihl MS-391
Huskee 35 Ton
Chevy 1500 Crew
13 & 15 year old work force
Re: Sulfur smell
« Reply #1 on: December 22, 2014, 03:21:52 AM »
Is there the same smell from the cold side as well?
Roger2561
Re: Sulfur smell
« Reply #2 on: December 22, 2014, 04:22:13 AM »
Perhaps a good flush or 2 of the tank is in order to rid it of sludge at the bottom of the tank.  We had to do that to the water heater at the fire house when I was in the EMS.  The smell from it would smell like a really bad (or good depending on your perspective) fart.  Roger
CB Classic Edge 550 HD
JD LX277AWS
Stihl 021
Stihl MS 311
2012 Honda Goldwing GL1800
New Hampshire
aries9245
  • OWF Model: Cl6048
Re: Sulfur smell
« Reply #3 on: December 22, 2014, 05:15:55 AM »
Like slim said .. Is it well water my well is 500' deep and the sulfur and iron manganese  is so bad I need to disinfect my well every 2 months  I also hv a inline filter to eirator to water softener and I still get the sulfur smell on occasion horrible..
Joe
Dodge 5500 dump
Ford f450 dump
Cat 303cr excavator
Cat 246 skid steer
Kubota l4610 tractor
2 sthil farm boss saws
Shrek1112
Re: Sulfur smell
« Reply #4 on: December 22, 2014, 05:36:50 AM »
 Slimjim - it is hot water only cold has no smell.
Stihl MS-250
Stihl MS-391
Huskee 35 Ton
Chevy 1500 Crew
Re: Sulfur smell
« Reply #5 on: December 22, 2014, 08:09:15 AM »
So do you have a water softener in your house?
Shrek1112
Re: Sulfur smell
« Reply #6 on: December 22, 2014, 08:25:42 AM »
Yes we do, salt is full softener is only a 2 years old.
Stihl MS-250
Stihl MS-391
Huskee 35 Ton
Chevy 1500 Crew
Re: Sulfur smell
« Reply #7 on: December 22, 2014, 09:04:09 AM »
Softeners cause the anode rod to stink like sulphur if after a backwash all of the brine wasn't rinsed throughly from the resin bed. I have a feeling that for some reason your new set up with your hot water tank is letting salty brine water from the softener hit the anode rod and is causing it to stink. My water would stink after my softener did a backwash so I just removed the rod. You can get a different type of anode rod that doesn't smell or you can just remove it since your water softener should be taking care of your hard water issues that would lead to hurting your heater tank
Shrek1112
Re: Sulfur smell
« Reply #8 on: December 22, 2014, 09:09:43 AM »
Thanks homdaracer- I have pulled the old rod and their is no metal left.  I am going to flush as previously recommended and then try just a plug and see what comes of it.  Thanks again all for the assist.  :thumbup:
Stihl MS-250
Stihl MS-391
Huskee 35 Ton
Chevy 1500 Crew
AirForcePOL
  • OWF Model: G400
Re: Sulfur smell
« Reply #9 on: December 22, 2014, 09:43:06 AM »
I have that same issue as well but it isn't caused from the boiler.  What I have done in the past is drain the water heater, put a little bit of bleach in the tank and fill it back up.  Let it sit for a while and then drain it again.  It should take care of the smell.
Athens, Illinois
Dealer for HeatMaster SS
Stihl MS 290
Troy Bilt 27 ton splitter
Re: Sulfur smell
« Reply #10 on: December 22, 2014, 01:16:45 PM »
« Last Edit: December 22, 2014, 01:19:29 PM by Sloppy_Snood »
Jwood
  • OWF Brand: P&M Ultimizer
  • OWF Model: Bl 28-40
North Central Minnesota
Stihl MS 270c
Stihl MS 461
Blacked out Fiskars X27
06' Silverado 2500HD Duramax
Shrek1112
Re: Sulfur smell
« Reply #12 on: December 22, 2014, 07:10:07 PM »
Sloopy_Snood- great link thanks. I have removed the old anode, there was nothing left of the metal and a sewage like slime on it, flushed the tank twice and then capped the rod hole and filled as normal. Smell is gone for now and will monitor (the wife will for sure). Thank to everyone for the responses and help.  :) :)
Stihl MS-250
Stihl MS-391
Huskee 35 Ton
Chevy 1500 Crew
Re: Sulfur smell
« Reply #13 on: December 23, 2014, 02:39:53 AM »
 :post:
Re: Sulfur smell
« Reply #14 on: December 24, 2014, 01:29:58 PM »
Glad it helped Shrek but I would consider putting an aluminum cathode rod in to replace.  Just change it out every 2-3 years. ;)
