Author Topic: motorized 3 way diverter valve  (Read 7358 times)
clydem
  • OWF Model: 5036
« on: December 22, 2014, 03:22:48 PM »
 Can anyone recommend a reliable brand & place to purchase a 24 v motorized 3 way diverter valve for my heating system?
Thanks
Clyde
CB5036    inst: 11/20/11
JD 4600,  G27 IWB
Re: motorized 3 way diverter valve
« Reply #1 on: December 23, 2014, 02:57:51 AM »
Could I ask why? Taco makes some good ones but you may not need it if you plan on using it to control water flow to your water to air heat exchanger.
clydem
  • OWF Model: 5036
« Reply #2 on: December 23, 2014, 06:41:46 AM »
I would like to be able to selectively bypass the HX on days when the outdoor temps are mild to prevent the temp in the house from becoming uncomfortably high .
This would help me unnecessarily burning more wood than is required to maintain the home temp at a comfortable level.  I do this now manually with ball valves and can extend my burn times and lower my wood consumption.
I am looking for a valve like the one in the picture.
thanks
Clyde
JD 4600,  G27 IWB
Spankyscl6048
  • OWF Model: CL 6048
« Reply #3 on: December 23, 2014, 06:31:45 PM »
I had the same issue. I installed the Taco 561-5 valve got it from supplyhouse.com around $160
smitty33
« Reply #4 on: December 24, 2014, 08:18:45 AM »
I had one on mine. It was a johnson control, but i took it off this year, it restricted the flow too much.
