Author Topic: diy sidearm heat xchanger  (Read 8189 times)
dukethebeagle
  • OWF Model: 0001 hot tamali
« on: December 26, 2014, 03:42:25 PM »
anyone see the diy sidearm xchanger build on youtube.
wonder if its as good as what u get at anderson
almost looks the same
« Last Edit: December 27, 2014, 05:16:27 PM by dukethebeagle »
austin qc
bluegrass rules
proud appalachian
aries9245
  • OWF Model: Cl6048
Re: diy sidearm heat xchanger
« Reply #1 on: December 27, 2014, 04:22:48 AM »
Can u post the link?
Joe
Dodge 5500 dump
Ford f450 dump
Cat 303cr excavator
Cat 246 skid steer
Kubota l4610 tractor
2 sthil farm boss saws
dukethebeagle
« Reply #2 on: December 27, 2014, 04:07:12 PM »
austin qc
bluegrass rules
proud appalachian
juddspaintballs
« Reply #3 on: December 27, 2014, 05:55:58 PM »
Sure, it'll work.  The Anderson version might be ribbed so it exchanges the heat a little bit better, but that style will work fine if you make it long enough.  The longer you make it, the better it will exchange heat.
aries9245
  • OWF Model: Cl6048
« Reply #4 on: December 28, 2014, 05:42:45 AM »
I made a few just like that the only problem with them if you make to long long you will loose the sifon part of the water flowing and might need a circ pump.. It's what I experienced others may have a different opinion ..
Joe
Dodge 5500 dump
Ford f450 dump
Cat 303cr excavator
Cat 246 skid steer
dukethebeagle
« Reply #5 on: December 28, 2014, 06:44:51 AM »
how long do you suggest.the one on u-tube is 52 inches.
think thats to long
austin qc
bluegrass rules
proud appalachian
« Reply #6 on: December 28, 2014, 06:48:19 AM »
Make it as long as possible without going above the tank top.
aries9245
  • OWF Model: Cl6048
« Reply #7 on: December 28, 2014, 08:49:27 AM »
Is that the trick Slim as long as u don't go above the tank it will keep the sifon going?
Joe
Dodge 5500 dump
Ford f450 dump
Cat 303cr excavator
Cat 246 skid steer
« Reply #8 on: December 28, 2014, 10:22:49 PM »
I am not sure how the make the groves on the Anderson version but from the pics I have seen, it looks like they just spiral a worn out pipe cutter down the pipe. I doubt this really does much. The slight increase of surface area will probably just accumulate sediment and not do anything. A twisted tube is much better. It increases surface area and changes flow pattern to get much better heat transfer.
It usually costs over $100 for a sidearm with this type pipe. I don't know if you can get just the pipe anywhere to build your own.
« Reply #9 on: December 29, 2014, 02:47:42 AM »
That's the trick, if I want more surface area, I use an old trick from the Solar Thermal guys, back in the 70's they used scrap wire to loosely wrap around the 3/4 inch domestic pipe and solder it at least 2 times every loop.
Chas
  • OWF Brand: Ridgewood
  • OWF Model: 6000
« Reply #10 on: December 29, 2014, 06:02:29 AM »
The total length of mine is 32" and the distance between the boiler inlet and outlet is only 22". I built it myself to fit my water heater. It connects to the drain on the bottom and to the relief valve outlet on the side close to the top. It's 1" copper inside of  2" copper. I built mine like Slimjim suggested....I wrapped a piece of #12 copper wire around the inner 1" pipe and soldered it in place to create some turbulance and/or swirling action of the boiler water. I don't know if it helps but it sure can't hurt. I'm sure longer would be better but it keeps up with 3 adults in the house.
Dolmar 035
Stihl 026
Stihl 260
Speeco 25 ton splitter
John Deere 4720
Polaris Ranger 800
Middle of the mitten, Michigan
