Author Topic: WOODMASTER 4400 OVER BOILING & USING WATER  (Read 47296 times)
Re: WOODMASTER 4400 OVER BOILING & USING WATER - RESOLVED!!! YIPPEE!
« Reply #15 on: November 25, 2010, 09:29:24 AM »
Well, here is what I did to find my leak. I put a bucket on top of the flue and watched for smoke to come out. Turns out my door which I had put new fire rop on was the culprit.  I had bought the largest size rope at Tractor Supply (TSC) which was 5/8s in diameter.  They also included a small tube of high temp gasket seal with it, but it didn't go very far. This time I went to Rural King and found their 3/4 inch rope and bought a large tube of gasket sealant. I toook off the old rope and disc grinded the door area to bare metal. I applied a liberal amount of sealant and then secured the new thicker rope. I left the door open untile the sealant dried before closing it. Now I am operating at 170 to 177 at the highest. I have my stove set to 160 so the fan kicks off when it gets to that temp.
Would I have done any damage to my stove with having it burn so hot and boiling out the water?
It seems to be working fine now. My house is nice and toasty warm and I do not have to constantly fill it up with water.  I'm very happy again.
THANKS for all the advice and suggestions!
i'm lost.. your fan kicks off at 160?  but your now operating at 170-177?
s
Dirtslinger
  • OWF Brand: Woodmaster
  • OWF Model: 4400
« Reply #16 on: November 25, 2010, 11:38:36 AM »
s
Maybe that is when his fan kicks on.
Dirtslinger
Brockway, PA
« Reply #17 on: November 25, 2010, 04:29:05 PM »
i can see a 10 or 12 degree rise in the water temp at teh stove after the fan shuts off, IF no hot water is being used to heat anything when the fan shuts off. If you have a good load of wood in th e stove and the fan has been roaring away for some time to get the water up to temp, when it shuts off (the fan)  there will still be a raging fire for a few moments and a very very hot bed of coals until all the air in the stove is used up. If no heat is being drawn from the stove and it is only circulating the water could easily pick up 10 or 12 degrees before the fire is cooled down. that is one reason many OWB owners that use their stoves all summer long actually lower the high temp of their stove, they don't do it just becasue they dont need that high temp for their domestic hot water but it also prevents summer time boil overs from "heat rise" when the fan shuts off.
mober
« Reply #18 on: November 25, 2010, 04:44:48 PM »
i agree with willie
it happens to me sometime when i use hardwood and get a really nice coal bed and the burn chamber gets really hot and the steel will hold that heat and thats why it can keep raising the water temp even after the fan shuts down.
my burn box is 3/8 inch thick by the way , homemade.
its just great experience to build one yourself and you get to know everything about the stove inside and out strongest point and weakest point.this thing is make me so proud everyday i dont use propane and every single log i feed it i thank god for for blessing me to be able to build it!
jackel take your time with your build it looks great dont rush it.
i enjoyed building mine so much i want to build another one just for the heck of it :bag:
« Reply #19 on: November 30, 2010, 07:54:33 PM »
i can see that happening willie...  i've just never experienced it with my stove even in warmer weather.    My aquastat has been on 150 since oct 1, and when the fan shuts off a few minutes later it may creep to 153 but no more than that.
« Reply #20 on: November 30, 2010, 08:38:31 PM »
you may not have it happen on yours but it does happen that is why some guys turn their heat down in the summer, to allow for this to happen.
tlynholland
« Reply #21 on: December 03, 2010, 07:20:10 PM »
I set my stove temp to operate at 160. I think it is set to kick on the fan when it drops 20 degrees below that.  I usually always burn oak, maple, hickory or ash hardwood. My stove fan runs until it hits 160 degrees and then kick off but my temp goes up another 10 degrees or so depending on the weather and the wood and the load I have in it.
What temp do most of you have your stove set to operate at?  What wood do you burn?  How often do you empty all of your ash?  I do not have an auger other than my arms and a shovel so I empty mine out once or twice a week and then build a new fire.  I have a nice ash pile back behind my stove.
« Reply #22 on: December 03, 2010, 08:17:18 PM »
i run 160 also and my temp creeps up anywhere from 5 to 10 degrees depending on if my system is using hot water or not when the blower shuts off. I too have no augers (or other bells and whistles) on my home made stove, i let the ashes build up  and take out about 1 full wheel barrow every three or 4 weeks. I burn mostly dead elm  and any other kind of dead wood i find on teh forest floor (it is hard on the chains on my saws but i like to think i am helping keep the forest cleaned up)
