Author Topic: Install costs  (Read 5874 times)
brimfield
Install costs
« on: January 01, 2015, 06:06:48 PM »
I am ready to add a Central 1450 this spring. One of the things that gives me pause is the price to install it. I am looking at a 50' run from the unit to the house and one question is do I need Thermopex in the house or just under ground? Next qustion is what others have paid for parts to install the unit themself?
MerrellRoofing
  • OWF Brand: P&M
  • OWF Model: BL 34-44
Re: Install costs
« Reply #1 on: January 01, 2015, 06:36:38 PM »
You only need thermopex underground. It's expensive but worth it. After that about $150-300 per heat exchanger depending on your situation. And copper pipe and fittings will add up quickly.  Many different installation options. Just depends on how elaborate you want it to be, or need it to be.
Mid-Michigan
Husqvarna-51-261-372xpg-395xp
Chevy Dually Dumpx2
5050racing
  • OWF Brand: CB-1450
Re: Install costs
« Reply #2 on: January 02, 2015, 06:31:28 AM »
My 1450 did myself 40' underground pex buy it don't skimp there $600 have two,pumps and other stuff around &1.500 fittings,domestic hot water x-change,the pad area,all done myself follow CB install very easy to follow pictures and SUNSHINE TREE N LANSCAPE IN NJ great help even with them not installing it!!
aries9245
  • OWF Model: Cl6048
Re: Install costs
« Reply #3 on: January 02, 2015, 07:06:12 AM »
I would agree expect a budget of around $1500 give or take a few..
Joe
Dodge 5500 dump
Ford f450 dump
Cat 303cr excavator
Cat 246 skid steer
Kubota l4610 tractor
2 sthil farm boss saws
5050racing
Re: Install costs
« Reply #4 on: January 02, 2015, 07:30:55 AM »
My own backhoe to dig trench set unit so it does or could add up one year of oil savings
brimfield
Re: Install costs
« Reply #5 on: January 03, 2015, 06:59:19 AM »
Thanks to all for the feedback. I would definitely use the ThermoPEX;   I am not going to lose heat by cheeping out there.  I am going to put in a 50 plate heat exchanger to tie into my two zone base board heat and my water heater that runs off my boiler. I need to find some good plans for the plumbing and save up for that. I do wish I had done this years ago but  I could not have done this then.
« Last Edit: January 03, 2015, 07:39:45 AM by brimfield »
5050racing
Re: Install costs
« Reply #6 on: January 03, 2015, 01:04:11 PM »
Go to central boilers site and click on installation on left side and scroll down till u find your set up
UPSGuy03
  • OWF Brand: Cenrtal Boiler
  • OWF Model: E-Classic 1450
Re: Install costs
« Reply #7 on: January 03, 2015, 06:00:11 PM »
i didnt do a heat xchanger just ran it direct right into my existing oil burner. altho i did have to move my circ pumps to supply side to 'push" the flow instead of pulling it through the zone. no problems at all : )
Great Meadows New Jersey
5050racing
Re: Install costs
« Reply #8 on: January 04, 2015, 11:34:07 AM »
Same set up I have works great I have a old oil boiler direct plumbed ups guy,the diagram is on CB website you just better keep up on your water quality test n keep it in range nobody talks about how important this is to your life  expectancy of your setup,it will rot from the inside quicker than you think!
« Last Edit: January 04, 2015, 11:39:50 AM by 5050racing »
