Author Topic: Having problems With my boiler going under pressure  (Read 12157 times)
robash9608
  • OWF Model: Shop Built
« on: November 11, 2010, 10:58:29 AM »
I built my furance about a year ago and I've been having problems with the firebox going under pressure. I've got a 146 cfm fan mounted on the door. It's a double pass flue design with 6in square tubing as the flue. The chimney is about 6 ft high. Seems like i might have a draft problem, you can look at the top of the chimney and see the smoke puffing and also the smoke discharges back through the blower. I've been burning 1 year seasoned oak firewood.  Any thoughts of why this would happen??
Husqvarna 272xp
Husqvarna 55 rancher
Stihl 261
Homemade 30 ton splitter
Shop Built Furnace
Guru
    • Mike's Advanced Heating
Re: Having problems With my boiler going under pressure
« Reply #1 on: November 11, 2010, 12:40:57 PM »
I would start by cleaning the chimney.  If the chimney isn't insulated it will collect creosote and close the opening.
Mike
Nature's Comfort Territory Manager
Caro MI
http://www.mikesadvancedheating.com/
« Reply #2 on: November 11, 2010, 03:39:31 PM »
i am thinking the same as guru. if your double pass flue is collecting and starting to plug in the corners you may be creating a draft slow down and causing back draft and this is sucking enough fresh oxygen down the flue to ignite the gas in the flue and causing puffing out the door and smoke rings out the stack
a good cleaningn is in order for starters
MattyNH
  • OWF Model: 7300E ; S-275
« Reply #3 on: November 11, 2010, 06:30:45 PM »
Sounds like your stack could be plugged. Not sure where you live..But on warm days or late spring I avoid throwing in wet/green wood..Doesnt run enough..What I found that helps out with creasote is Ash Trol-MC by CB..My stack is 20FT up..Havent had a prob with stack plugging up..2nd season using it..Let me know how you make out..
Crown Royal 7300E (2021)
Aqua-Therm S-275 (2006)
Jonsered 2188
Jonsered 2165
Jonsered 2050
Kubota L3800DT
robash9608
« Reply #4 on: November 12, 2010, 06:36:18 PM »
The chimney is clean, thats the first thing that I did when I started to have the problem. I have burned green wood and it seemed not to have the problem as bad. Just wondering if the wood is to dry?
Husqvarna 272xp
Stihl 261
Shop Built Furnace
BFB Builder
  • Where ever you go there you are.
« Reply #5 on: November 14, 2010, 11:16:54 AM »
Sounds like we are having similar problems with diffrent results. My stove also huffs and puffs mine does this for about 5 min 15-20 min after I stoke. She  also creates excessive smoke. see the post Smoke troublefor the fix I am trying I will keep evoryone informed how it goes.
Owatonna  1700, Husky 575xp, 55 Rancher, Echo top handle, One big fat bastard homemade OWB
robash9608
« Reply #6 on: November 24, 2010, 08:23:19 PM »
I extended my flue down about 8 inches from the bottom of the firebox and still continue to have the same problems.. I have noticed that if I stack the wood on the sides of the firebox, (not in the flowpath of the fan) I don't have the problem. Does this indicate that I might need a larger fan??
Husqvarna 272xp
Stihl 261
Shop Built Furnace
« Reply #7 on: November 24, 2010, 08:57:24 PM »
im going out on a limb here and say yes..when you stack your wood in teh path of the fan you cause it to burn (or smolder) more rapidly and this is causeing more gas (instead of flame) now with what you describe as a double path  chimney this must mean you have at least 3 or four elbows in your exhaust pipe. each one of these elbows takes away from your chiney draw. so you need more air to push it out. also this may be causing yoru "going under pressure" if this in fact means your stove is back drafting (sucking air down the chimney)  and  then having a mini explosion in the fire box that causes the smoke and gasses to exit where ever they can (around door gaskets and blower seals)
so it  looks like bigger fan or less wood?
robash9608
« Reply #8 on: November 25, 2010, 12:32:08 AM »
Thanks Willie
Husqvarna 272xp
Stihl 261
Shop Built Furnace
