Author Topic: Bio burner  (Read 11930 times)
FF119
  • OWF Brand: Soon!
  • OWF Model: none
Bio burner
« on: February 05, 2015, 10:31:55 AM »
I was watching a video on a bio mass burner called Bio-burner. It says it burns wood chips,sawdust, and horse manure w/ bedding! Have a small farm and lots of manure but in the video it says it has to be processed through there processor. Sounds $$$$$$. Has anyone looked into this further?What a great concept for small farms with 3-5 horses. Free Manure Free Heat.
http://bioburner.com/
http://bioburner.com/products/biomass-processing-equipment/
CountryBoyJohn
  • OWF Model: MF 10,000 E
Re: Bio burner
« Reply #1 on: February 05, 2015, 10:45:44 AM »
Yeah, I can't see that paying off for a standard home owner.  95% of the folks on here are burning wood and the rest coal or wood chips.  Probably won't find any poop burners.
2013 F250 6.2L Lariat
Stihl MS290
DHT 27 Ton Log Splitter
Woodchuck Log Jack
56, 57, 58 Ferguson TO-35
Knox County, IN
Re: Bio burner
« Reply #2 on: February 05, 2015, 11:25:08 AM »
Any Biomass burner can burn manure if it is dried down to 40% or so moisture content, The lat I knew the Bio Burner was only tested with the EPA lab for pellets so I'm not sure how it can be promoted as a true Bio Mass boiler.
tulenutn2o
  • OWF Brand: HeatSource1
  • OWF Model: Earth Energy 190
Re: Bio burner
« Reply #3 on: February 05, 2015, 01:56:42 PM »
I believe burning poop is common in India, and places like that. Works good for them. Throw a shovel full in every now and then. Don't forget to let us know if it smells like chicken...... ;D
yotehunter66
  • OWF Brand: Woodmaster
  • OWF Model: 4400
Re: Bio burner
« Reply #4 on: February 05, 2015, 04:54:24 PM »
Interesting.
Husky 372xp 24"
Makita DCS520i 20"
Poulan 2300 18"
Troybilt 27 ton log splitter
Re: Bio burner
« Reply #5 on: February 05, 2015, 05:19:53 PM »
Early pioneers used to collect the buffalo poop (when dried :) ) toss them in the fire as a heat source so the way I see it is, it should work in a boiler.  But, does anyone know if burning dung gives off gases that may corrode the mild steel?  Roger
AirForcePOL
  • OWF Model: G400
Re: Bio burner
« Reply #6 on: February 05, 2015, 05:31:41 PM »
I can't see poop having much of a btu content.  I didn't watch the video but it seems like it would take a lot of it and frequent loadings.
Athens, Illinois
Dealer for HeatMaster SS
Stihl MS 290
Troy Bilt 27 ton splitter
CountryBoyJohn
Re: Bio burner
« Reply #7 on: February 05, 2015, 05:49:31 PM »
And frequent "unloadings".  >:D Sorry I couldn't resist!
Stihl MS290
Woodchuck Log Jack
Knox County, IN
Re: Bio burner
« Reply #8 on: February 05, 2015, 05:51:51 PM »
searching the net  comes up with 8500 btu in a pound of dried cow manure from a feed lot. so if you burn 8 cords of oak a year you would need about 16 tons of dried cow manure. How many pounds of wet manure would you need to get 1 pound of dry manure?
you would need a big laydown area to dry that out cause i aint never seen a pile ever dry out :o
AirForcePOL
  • OWF Model: G400
Re: Bio burner
« Reply #9 on: February 06, 2015, 05:03:51 AM »
Lol this is true!
Athens, Illinois
Stihl MS 290
Re: Bio burner
« Reply #10 on: February 06, 2015, 05:49:55 AM »
Not sure about when its dry, but when we had the dairy we considered investing in a digester to capture the methane and burn it in a generator. I know methane is somewhat corrosive as they have special oil for the Cat generators at the local landfill that burn methane collected from the garbage.
wissel12
  • OWF Model: 7500
Re: Bio burner
« Reply #11 on: February 06, 2015, 06:40:21 AM »
You would have to turn ton to gallons.
10 tons of water = 2690 gallons
2690 x 8.34 x 1.02 sg. gr x (percent solids in the manure)
That would give you dry solids
Say it was 20%
2690 g x 8.34 x 1.02 sp . gr x .02=915 lbs dry solids
8.34 is the weight of water per gallon
Must wet sludge at a waster water plant is under 10% solids
03 Duramax 72000 Miles
Massey Ferguson 275
WD 45
OC4
Stihl Farm boss 290
Stihl 025
Strasburg, Ohio
