Author Topic: Boilers  (Read 21410 times)
Roscoe
  • OWF Brand: Hawken
  • OWF Model: HE2100
  • Southeast Michigan
Re: Boilers
« Reply #15 on: February 10, 2015, 06:38:15 PM »
I think I finally have my 7500 with fan option dialed in @ 185 low 195 high. Burning semi seasoned everything but hardwood. Still not used to tending to it 2x a day and still a little gun shy on losing a solenoid due to creosote. Minimal creosote since bumping up the temps.
JD 7775
Kioti DK35
Bobcat S250
All Wood Oak Series
Stihl 036pro, 362c, 064
Husk 385,570
Shindiawa 416
Griffin 14' Dump
wissel12
  • OWF Model: 7500
Re: Boilers
« Reply #16 on: February 10, 2015, 07:23:37 PM »
High the temp the less creosote you will have. Mine comes on at 183 off at 190.
03 Duramax 72000 Miles
Massey Ferguson 275
WD 45
OC4
Stihl Farm boss 290
Stihl 025
Strasburg, Ohio
tinfoilhat2020
  • OWF Brand: POS
Re: Boilers
« Reply #17 on: February 12, 2015, 07:26:28 AM »
im running 9ft of stack, helped out recovery times for sure. i can throw anything in that sucker now and it will burn. only takes about 2 min of that door being open and u got a fire raging
right2bear
Re: Boilers
« Reply #18 on: March 22, 2015, 05:54:48 AM »
I paid for Ridgewood's 8ft pre built stack... dropped right in after grinding down the bead inside the stub. It surely helped my recovery times by a lot. My problem is excessive creosote no matter what wood we run... almost like the inside of the tank has a coating of something that will not stop melting. I have never seen so much tar all over the damper door, spilling out onto the ground, destroyed the rope gasket within the first two months of running the stove.
Hell I run the thing at a 200° shut off and 196° turn on.
I also have been burning nothing but well seasoned wood so...
U.P. Doug
  • OWF Model: 7500
Re: Boilers
« Reply #19 on: March 22, 2015, 06:56:26 AM »
I am not sure why my stove is so different? I have had no issues with creosote, my door is completely free of it, and I have been burning wood cut in the fall the last few weeks. I have the stock stack but I did fabricate a fan for the door that blows a very small amount of air, around 30cfm, to help in burning the green wood. I do not load my wood right up to the door. I rake the coal bed forward and stack wood 3 rows high in the back and middle of the stove. My temp is set at 182 high 172 low.
golffanman
Re: Boilers
« Reply #20 on: March 24, 2015, 04:09:05 AM »
Wow right2bear I'm on my 2nd year and have no creosote on the door at all. There is creosote in the firebox, but nothing dripping out my door. Last year I burned green wood, this year drier wood. Nothing like you are experiencing. What type of wood are you burning? Mine is a mixture. My high temp is 175°.
Huskee 22 Ton Splitter
Husqvarna 450 Chainsaw
woodman
  • OWF Brand: hawken
  • OWF Model: he1000
Re: Boilers
« Reply #21 on: March 24, 2015, 06:00:24 AM »
You guys having trouble with creosote at the door, is there any chance the stove is just off level? If so try shimming the legs in the front a little to make it tip back ever so slightly.
right2bear
Re: Boilers
« Reply #22 on: March 27, 2015, 09:21:21 PM »
I'm burning primarily 2yr old ash and elm, with a mix of red oak.
Re: Boilers
« Reply #23 on: March 28, 2015, 03:30:41 AM »
Right2bear, have you got an air leak around the door gasket? Could you replace the gasket and tighten the door?
Roscoe
  • OWF Brand: Hawken
  • OWF Model: HE2100
Re: Boilers
« Reply #24 on: April 05, 2015, 03:46:23 PM »
Bump....................anything new guys?
JD 7775
Kioti DK35
Bobcat S250
All Wood Oak Series
Husk 385,570
Shindiawa 416
Griffin 14' Dump
right2bear
Re: Boilers
« Reply #25 on: April 05, 2015, 06:25:12 PM »
No air leaks... still massive amounts of creo-evil :bash:
Chicken farmer
  • OWF Model: 2000
Re: Boilers
« Reply #26 on: April 06, 2015, 05:10:57 PM »
I get lots of creosote also. Sometimes it drips from the door. Burning 3 year old oak and hickory. Some silver maple too, but not much.
Midwestern Ohio
