Author Topic: Installing new door rope gasket  (Read 10500 times)
jerkash
  • OWF Brand: Legend
« on: February 11, 2015, 06:40:24 PM »
What is the best way to install a new door rope gasket?
I've heard of putting in the silicon, the rope and then more silicon
I've heard of putting in the silicon then the rope
I've heard of putting in the rope and then silicon
tawilson1152
  • OWF Brand: Crown Royal
  • OWF Model: 7300
Re: Installing new door rope gasket
« Reply #1 on: February 11, 2015, 06:58:22 PM »
I did mine this fall and went silicone then rope, then mounted the door and used another layer of silicone, then wax paper and then closed the door.
duke
  • OWF Model: MF5000
« Reply #2 on: February 12, 2015, 01:09:35 PM »
If you do put silicone on outside of gasket make sure and use wax paper as said or make sure and let silicone completly dry before shutting your door or it will pull your gasket back out next time you open it. I learned this the hard way :bash:
06 Duramax
08 Polaris Ranger XP
MS 310
28 ton Swisher
aries9245
  • OWF Model: Cl6048
« Reply #3 on: February 12, 2015, 01:16:09 PM »
Make sure u use a high temp silicone used for stoves or high temp applications ..
Joe
Dodge 5500 dump
Ford f450 dump
Cat 303cr excavator
Cat 246 skid steer
Kubota l4610 tractor
2 sthil farm boss saws
yotehunter66
  • OWF Brand: Woodmaster
  • OWF Model: 4400
« Reply #4 on: February 15, 2015, 08:17:53 AM »
We need a good instructional video on some of this stuff.
Husky 372xp 24"
Makita DCS520i 20"
Poulan 2300 18"
Troybilt 27 ton log splitter
Bondo
  • OWF Brand: Home built
  • Master General Re-Engineer
« Reply #5 on: February 15, 2015, 09:46:19 AM »
Ayuh,.....    The 1st one I put on my homemade boiler, I used rutland door gasket, 'n the rutland cement,.....
It didn't last the season,....
2nd time, I used the rope gasket, 'n hi-temp sillyseal,.....
Put the sillicone on the door, then the rope, then closed the door to hold it in place,...
That was several years ago, 'n when checkin' it the other day, It's still just Fine,....
MD20/20
  • OWF Brand: Nature's Comfort
  • OWF Model: 325G
« Reply #6 on: February 15, 2015, 11:34:21 AM »
So you changed the gasket with the fire going?
Central MD
kommandokenny
  • OWF Brand: woodmaster
  • OWF Model: 4400
« Reply #7 on: February 15, 2015, 12:30:00 PM »
Anybody heard of using a high heat enamel paint.
And an oversized rope
Supposed to come off easier next time you replace the gasket.
No silicon to clean out?
read it somewhere"
kk
« Last Edit: February 15, 2015, 12:32:38 PM by kommandokenny »
PARRY SOUND ONTARIO
2012 RAPTOR
NORTON COMMANDO
H.D. ROAD KING
Sthil 026,038
Echo CS 310 [grandaughters]
SWISHER 22 TON
CANAM 850 tracked
GREAT DANE X 3
hoardac
  • OWF Brand: Heatmaster G-200
« Reply #8 on: February 15, 2015, 01:04:08 PM »
I got some from Slimjim that worked really well just as flexible as when I installed, it looks like this stuff. Just put some hi temp silicone in the slot.
http://www.atlantexmfg.com/pyrotex-sg-rope/
Bondo
« Reply #9 on: February 15, 2015, 01:46:31 PM »
Ayuh,....   Just not runnin' Full tilt like it has been, tryin' to keep with with these Sub-Zero temps,....
I used the graphite rope, 5/8", I think,...   the smaller of the 2 sizes on the bulk spool at my local hardware store,...
'n I glued it on with a tube of red Hi-temp rtv from my local Napa,...
I used my angle grinder with a wirebrush on it to clean off the ole rope, 'n furnace cement,...
Slathered the flange with the silliseal, positioned the rope where it wanted to be, lined it with suranwrap, 'n closed the door,....
By next day, most of the suranwrap residue had burnt off, 'n the job was called a Success,....
It's been a couple seasons, 'n I'm thinkin' the top, 'n bottom could benefit from the wider piece of rope I've still got,....
Maybe I'll give it a shot, when it warms up abit,....
'ell,....   Zero° would be a nice gobal warmin' heat wave, today,....    ::)
