Pages: 1 [2] 3
Author Topic: Burning coal without a shaker grate?  (Read 24918 times)
DaveWertz
  • OWF Model: H4
Re: Burning coal without a shaker grate?
« Reply #15 on: February 17, 2015, 09:24:04 PM »
No it will not hurt it not using fire brick.
2001 F150 7700 series
09 Harley Superglide custom
Stihl Farmboss 290
wissel12
  • OWF Model: 7500
« Reply #16 on: February 18, 2015, 06:24:32 PM »
I went to my local feed mill today and bought some coal. I got 180 lbs to try out. It seems to be burning good. I put really dry oak down first and then the coal. It sells for 180 a ton. I took a picture, but the up loader is full. I'll try later.
03 Duramax 72000 Miles
Massey Ferguson 275
WD 45
OC4
Stihl Farm boss 290
Stihl 025
Strasburg, Ohio
walkerdogman85
  • OWF Model: H-4
« Reply #17 on: February 18, 2015, 08:39:58 PM »
I am impressed with coal. I gave some to a friend of mine who also has a hardy and just after one night he wants to go buy some bigger stuff. It has cut my wood usage more than 50% in the last 3 days at temps 0 and below at night! My job is based off of coal so I'm going to heat off coal....
Michael West
Central Ohio
wissel12
  • OWF Model: 7500
« Reply #18 on: February 18, 2015, 09:06:56 PM »
I'm with your friend. I'm going to buy half a ton on Friday. I think with the natural draft, It will only burn when real cold out side. I set my differential to 4. I tighten it up to keep the coal hot.
Massey Ferguson 275
WD 45
OC4
Stihl Farm boss 290
Stihl 025
Strasburg, Ohio
walkerdogman85
  • OWF Model: H-4
« Reply #19 on: February 19, 2015, 03:44:53 AM »
I'm not sure how to set my differential or I would do it. Coal does need alot of air.
Michael West
Central Ohio
wissel12
  • OWF Model: 7500
« Reply #20 on: February 19, 2015, 05:21:01 AM »
Here is a link for  honeywell aquastat. http://s3.supplyhouse.com/manuals/1350890933994/83991_PROD_FILE.pdf
When you take the cover off the aquastat. You will see a white dial. That is your differential. It should go between 5 and 25. It is on page 9 shows the white wheel. The big wheel in the front is your setting for your high limit.
I hope this helps.
Massey Ferguson 275
WD 45
OC4
Stihl Farm boss 290
Stihl 025
Strasburg, Ohio
walkerdogman85
  • OWF Model: H-4
« Reply #21 on: February 19, 2015, 06:06:27 AM »
Thanks, I saw the high point setting as i turned it i realized thats what it was as the fan was coming on and off as I adjusted it. Ill study the the link you sent me and set it closer. Thanks alot for the info
Michael West
Central Ohio
AirForcePOL
  • OWF Model: G400
« Reply #22 on: February 19, 2015, 10:09:59 AM »
I would recommend just buying a Ranco aquastat and replacing your Honeywell.
Athens, Illinois
Dealer for HeatMaster SS
Stihl MS 290
Troy Bilt 27 ton splitter
MD20/20
  • OWF Brand: Nature's Comfort
  • OWF Model: 325G
« Reply #23 on: February 19, 2015, 10:45:37 AM »
I like my Ranco a lot better than the old Honeywell aqua-stat- I can easily read the settings.
Central MD
walkerdogman85
  • OWF Model: H-4
« Reply #24 on: February 19, 2015, 11:37:04 AM »
I have heard that before about the Ranco, what makes it better than the Honeywell? I haven't had any issues with it in the 3 years I have had it.
Michael West
Central Ohio
walkerdogman85
  • OWF Model: H-4
« Reply #25 on: February 19, 2015, 11:50:48 AM »
What would you guys set the differential at?
Michael West
Central Ohio
Vincent Paul
  • OWF Model: 7500
« Reply #26 on: February 19, 2015, 03:38:17 PM »
hey wissel12, we also have a Ridgewood 7500, let me know how the coal works out.  I have a coal mine 7 miles from our farm which sells lump coal for $80/ton..................Vincent Paul
Stihl 025
Stihl 261
Stihl 361
New Holland TN 75A
Ford F-250 -- V-10
MD20/20
  • OWF Model: 325G
« Reply #27 on: February 19, 2015, 04:17:06 PM »
I like the digital display. It allows me to set it exactly where I want it (which is not always where it should be!).
Central MD
walkerdogman85
  • OWF Model: H-4
« Reply #28 on: February 19, 2015, 06:15:51 PM »
I looked at the aquastat and there was no differential wheel in the back. Looks like I'll be buying a different one for next winter, although since burning coal on these below 0 days the hardy is running often..
Michael West
Central Ohio
AirForcePOL
  • OWF Model: G400
« Reply #29 on: February 19, 2015, 06:26:19 PM »
Yea there's a few different models that Honeywell sells.  The one I had on my hardy was not adjustable and permanently set to a 10 deg differential.  Get on ebay, they sell ranco controllers for $43
Athens, Illinois
Stihl MS 290
Pages: 1 [2] 3
