Author Topic: white flames at below -0f  (Read 7237 times)
heat550
  • OWF Brand: Heatmor
« on: February 20, 2015, 01:23:34 AM »
 It was -10f and my 200ss does this if you keep loading 3-5 pieces of dry oak in every 3-4 hours .  water always above 150f
when you have door open fan on when loading and watch the flames change from yellow red blue to straight white .
when it does it you can feel mass of heat . anyone ever notice this . seen it few times only at -0f or colder .  cycle times are quit fast
also when its doing this .  I call it short loading the stove but wow does it heat up the house :)  Searched on net says its burning at 2900f with white flames .  Only noticed this sense burning some nice dry oak 20-25%
Heat550
Jwood
  • OWF Brand: P&M Ultimizer
  • OWF Model: Bl 28-40
Re: white flames at below -0f
« Reply #1 on: February 20, 2015, 06:24:47 AM »
Im not saying that you are not seeing white flames but I will say you are not burning at 2900degrees thats a bit warm I think.
North Central Minnesota
Stihl MS 270c
Stihl MS 461
Blacked out Fiskars X27
06' Silverado 2500HD Duramax
aries9245
  • OWF Model: Cl6048
« Reply #2 on: February 20, 2015, 07:48:34 AM »
White flames I'm courious I don't think I've ever seen that!
Joe
Dodge 5500 dump
Ford f450 dump
Cat 303cr excavator
Cat 246 skid steer
Kubota l4610 tractor
2 sthil farm boss saws
heat550
« Reply #3 on: February 20, 2015, 10:29:55 AM »
Here have a look .http://youtu.be/hBVIFigpaR0
Heat550
« Reply #4 on: February 20, 2015, 11:08:00 AM »
I get the same flames on my waste oil boiler when the air is just right, not 2900 degrees though, the cast iron firepot would never take that 8-12 hours a day.
aries9245
  • OWF Model: Cl6048
« Reply #5 on: February 20, 2015, 11:37:46 AM »
Ok I got was thinking something else !
Joe
Dodge 5500 dump
Ford f450 dump
Cat 303cr excavator
Cat 246 skid steer
heat550
« Reply #6 on: February 21, 2015, 01:32:05 AM »
I don't know if its 2900f but its dam hot . I read a bit more on it on the net about white flames . Its said its when the carbon partials
coming off a yellow to red flame ignites . I know it only did this white flame thing sense I burned nice dry oak . and yes I think 2900f would start milting stuff over time . But at below -10f and about 1 hour after loading stove . my cycle times fan on are fast like 10 -15 mins water temp of 150f to 170f  till its needs wood again 7-10 hours subzero. But I have good size load on the old 1996 model 200ss 5600 square feet . building temp range 45 f to 75f I feel lucky I got that video of it . Its the short loading 3-4 hours stove gets super hot .
Heat550
p.s. If I can  get info from website i will post it theres different color flame temps for organic and oils, gases .
heat550
« Reply #7 on: February 21, 2015, 01:55:24 AM »
The temperature range from Red to White: Wood
    Red
        Just visible: 525 °C (980 °F)
        Dull: 700 °C (1,300 °F)
        Cherry, dull: 800 °C (1,500 °F)
        Cherry, full: 900 °C (1,700 °F)
        Cherry, clear: 1,000 °C (1,800 °F)
    Orange
        Deep: 1,100 °C (2,000 °F)
        Clear: 1,200 °C (2,200 °F)
    White
        Whitish: 1,300 °C (2,400 °F)
        Bright: 1,400 °C (2,600 °F)
        Dazzling: 1,500 °C (2,700 °F)
I couldn't get info off a physics website but I  got this even 2600-2700f pretty dam hot .  :)
at less a good reference .  thought I share my findings might help others to .
Heat550
aries9245
  • OWF Model: Cl6048
« Reply #8 on: February 21, 2015, 04:49:16 AM »
That is a great shot of it !
Joe
Dodge 5500 dump
Ford f450 dump
Cat 303cr excavator
Cat 246 skid steer
