Author Topic: Getting Close to Shut Down Might want to check for paint  (Read 22773 times)
jamesbodeis
  • OWF Model: 7500
Re: Getting Close to Shut Down Might want to check for paint
« Reply #15 on: May 04, 2015, 06:48:25 PM »
Same here. Got some stuff floating. I would have thought if it was going to plug it would have by now though?
Ridgewood 7500
The thumb of michigan.
Jonsered 2260
chiselchain
« Reply #16 on: May 05, 2015, 05:35:52 AM »
me too. craig sent me a strainer to install after I shut down.
intensedrive
« Reply #17 on: May 06, 2015, 01:44:50 PM »
Have you tried running a few gallons out the back into a clear vessel to evaluate further?
intensedrive
« Reply #18 on: May 12, 2015, 11:18:00 PM »
everything clear on your check? No Paint?
golffanman
« Reply #19 on: May 15, 2015, 08:41:31 AM »
Last year my water looked milky. I had some plumbing work to do so I drained the system and reinstalled my water treatment. This year my water is clear.  :thumbup:
Huskee 22 Ton Splitter
Husqvarna 450 Chainsaw
automan77
  • OWF Brand: ridgewood
  • Just say no to propane
« Reply #20 on: May 15, 2015, 12:10:14 PM »
Cleaned the inside of my stove yesterday I'll  spray the inside with lube this weekend. I'm gonna drain mine and refill.  Also gonna pour a slab for it this summer.
Scott K
Stihl ms 311
Husky 455
St Clair County Michigan
Troy Built 27 ton splitter
jamesbodeis
  • OWF Model: 7500
« Reply #21 on: May 15, 2015, 02:50:42 PM »
Anybody gonna run all summer and heat your dhw?
Ridgewood 7500
Jonsered 2260
intensedrive
« Reply #22 on: May 15, 2015, 11:57:20 PM »
If you flush your tank, be sure to keep tabs on the water after refill.  Keep taking samples in clear vessel out the back drain port... Several gallons at a time to make sure everything is clear.  One flush and refill might not be all you need.  Always check the water quality out of the drain port.  If you drain a few gallons off and its clear, I think your good.
« Last Edit: May 16, 2015, 12:02:18 AM by intensedrive »
Chas
« Reply #23 on: May 18, 2015, 06:12:28 AM »
I had to drain off 40 gallons or so and refill because my water treatment PPM was a little on the high side, and my water looked clear..... other than a little dirty water right at first.
Dolmar 035
Stihl 026
Stihl 260
Speeco 25 ton splitter
John Deere 4720
Polaris Ranger 800
fireman69lfd
« Reply #24 on: May 18, 2015, 10:43:54 PM »
[Anybody gonna run all summer and heat your dhw?]
Hey James, I'm going to try and run all summer. I have for the last 8 years with a CB 6048, but its the first year with PM 250. Also planning to change temperature in our pool, the main reason for that is to keep the teenager home and create a cool place for her and friends to hang out. Sorry I can't remember what name pipe, or the shell Heat exchanger. I'm still sitting back trying to lay low from my 5th Neck surgury, NEVER Give Up
Russ
Near Okemo Mtn. Ski area Vermont
Vincent Paul
  • OWF Model: 7500
« Reply #25 on: May 26, 2015, 05:00:48 PM »
Speaking of shutting down, we are continuing to heat our DHW with our Ridgewood 7500 but are leaving for a few days.  Our plan is to let the fire go out ( rebuild when we get  home in 3 days ).  Now the dumb question, should I shut my pump off or continue to let it circulate?  As always, thanks for your time to respond...............Vincent Paul Meyers
Stihl 025
Stihl 261
Stihl 361
New Holland TN 75A
Ford F-250 -- V-10
« Reply #26 on: May 26, 2015, 05:13:25 PM »
Let it run, it will be fine.
Vincent Paul
  • OWF Model: 7500
« Reply #27 on: May 28, 2015, 03:04:59 PM »
Thank you SlimJim, I knew if anyone would answer it would be you.  Haven't been on here for awhile, ranching and farming ( and working a 12 hour/day job ) have consumed my time.  I always appreciate your help greatly.  vpm
Stihl 025
Stihl 261
Stihl 361
New Holland TN 75A
Ford F-250 -- V-10
