Author Topic: E1450 Season start up wierdness  (Read 4759 times)
UPSGuy03
  • OWF Brand: Cenrtal Boiler
  • OWF Model: E-Classic 1450
« on: October 03, 2015, 06:36:59 AM »
Hi all .. so last weeekend i figured i would fire her up after sitting for the summer months. after a Normal shutdown in march, when i went to start her up, the on/off switch ( its the switch that has a breaker in it?) had stopped working or tripped or went bad i dont know.. but anyway orderd a new one and will install and hopefully be up and running today.
Question is .... has anyone else had this hapen? the thing is only a year old so im wondering if its just a bad Mexican switch or should i be looking for something else wrong?
Nothing has changed since shutdown so im just kinda shrugging my shoulders?
Great Meadows New Jersey
Re: E1450 Season start up wierdness
« Reply #1 on: October 03, 2015, 11:15:57 AM »
Welcome to the life of a farmer, always have stuff that needs repaired even though it was fine when parked.
Had that just last week, scale on the baler worked perfect when I parked it, used it again less than a week later and within 100 feet said the baler weighed negative 56000 lbs.
In this day and age wouldn’t surprise me in the least if it was a mexican or china switch.
UPSGuy03
« Reply #2 on: October 03, 2015, 12:33:19 PM »
Ha ha no doubt !
well it was the darned switch... installed the new one and fired right up.
she is purring right now, waters at 95 on the way to 190 woo hoo !
Roger2561
« Reply #3 on: October 03, 2015, 04:51:04 PM »
Ha ha no doubt !
UPSguy03 - I don't have the E-1450, I have the E-1400 and (knocking on wood) I haven't had any problems with the electrical in mine.  The only problem I've bumped into is the weld seams that make up the welded in place air channel has separated a bit leaving a bit of crack.  I contacted CB and they said it was nothing to worry about.  Because it was in the vicinity of the water jacket, I hired a welder and welded it closed for me.  On the up side he said he was happy to see the way I was taking care of it and performing all of the maintenance.
It's not cold enough yet to fire up the E-1400.  I'm running the oil burner to take the chill off in the evening and during the day, Sunday.  I think I'll wait 'til later in the month to fire mine up for the season.  Good luck with your 1450.  I hope you have a hassle free heating season.  Roger
CB Classic Edge 550 HD
JD LX277AWS
Stihl 021
Stihl MS 311
2012 Honda Goldwing GL1800
New Hampshire
jeffsa22
  • OWF Model: E1450
« Reply #4 on: October 06, 2015, 06:45:09 PM »
Did the switch turn the lights on and not the controller or was everything dead
UPSGuy03
« Reply #5 on: October 06, 2015, 07:31:59 PM »
everything from the switch forward was dead.. no lights, fans or controller.. if i wiggled the switch it would beep ( i had the bypass open) so after replacing the switch all is good now.
