Author Topic: Wye strainer and Air Eliminator ?  (Read 5186 times)
« on: October 28, 2015, 11:39:02 AM »
Another post from a new member:
I'm in the design phase.   OWB will run to FHPE for DHW then to FPHE for the house boiler then back to OWB.   OWB loop not pressurized.  200' round trip.  Pretty basic.
Does anyone have an opinion on if a wye strainer is required ?  How about and air eliminator ?
Thanks
Kelly
Re: Wye strainer and Air Eliminator ?
« Reply #1 on: October 28, 2015, 11:45:18 AM »
I have both in my system, but I also installed the strainer a long time after the system was up and running, only reason I installed was I added a FPHE for my snow melt system. I have a ball valve immediately before and after so I can clean it and only lose a minimum of water. Some recommend a bypass around it so you can leave the system run while cleaning it, not sure if this is really required if you check it several times after the first start up in the shoulder season. I’ve yet to find anything in the strainer, but again my system ran a long time before I added it.
I’d highly recommend adding a fill valve in your basement, nothing like having to drag a garden hose in the dead of winter to top off your OWB.
While you have the trench open for your underground pipe go ahead and lay another pipe for water by your OWB, I did this last year and should have done it 15 years ago on the first install.
When I redo all my plumbing in the basement I plan on adding a solenoid activated fill valve, I already have the extra wire ran to the OWB and will install a pushbutton there to activate the solenoid to avoid overfilling and losing treated water, which can happen when you have a manual fill valve in the basement.
« Last Edit: October 28, 2015, 11:47:05 AM by mlappin »
vogelkj2001
  • OWF Model: BL 3444
« Reply #2 on: October 29, 2015, 12:14:38 PM »
What kind of air eliminator do you have ?   Automatic or manual, ect?
I have already planned on a filler (ball valve with drain) in my mech room ... installed in the cold return to the boiler.   I will use a washing machine type hose (dual female) to cross connect the to male threaded hose bibs and add backflow preventer on the domestic side just to be safe.... then I can fill/add from the garage... and I can the fill gauge from there.
Thanks
« Reply #3 on: October 29, 2015, 12:18:58 PM »
A reply from Mr. Vogul:
I have already planned on a filler (ball valve with drain) in my mech room ... installed in the cold return to the boiler.   I will use a washing machine type hose (dual female) to cross connect from a spigot in my mech room to the drain on the BV  ... add backflow preventer on the domestic side just to be safe.... then I can fill/add from the garage... and I can see the fill gauge from there.
Thanks
