Author Topic: Coal Experiment  (Read 19160 times)
Coal Experiment
« on: January 16, 2011, 06:41:32 PM »
As some of you know I've played with burning a lump or two of coal every now and then just to see how it does.  I finally called up a buddy who works at a coal dock and he said to come by and we'd load my truck down.  I took my truck up and hand loaded it completely full of softball to footlball size lumps.  I heaped it up and tried to place it to maximize my load.  When I left my ball was probably 5-6" off the ground haha.
Sooo..   for the last 3-4 days I've been playing with the coal and will continue to experiment and let you guys in on what I'm doing.
I'm heating 22-2300 sq foot double wide in a Natures Comfort 175 furnace.  The past several days have been typical winter weather, a lil warmer, but nothing crazy.  Lows 10-15 Highs 25-30.  Typically my burn times on seasoned hardwood can range from the shortest burns of 14 hour or so in zero weather to as much as 24 hours when the temps only bottom out in the high 20's.  Since I started burning a bit of coal, I'll go out at night and throw in probably 20-30 pound of coal.   Then add about 1/2 a load of wood over the coal, where as before I would cram it full.  My burn times are now easily over 24 hours.  I'll fill at 5 or 6 pm, go back out around 9 am open the door and smile.  There will still be wood in there and those chunks of coal will be laying there glowing red.  I'll usually just punch it around and wait for my evening fill.
This evening after a 24 hour burn I am sure that my stove would have went another 8-12 hours.  I threw in about 20 pound of coal, and about 1/3 a load of wood.  I'll update on how this done.  Tonigt it is supposed to be about 10-12  degrees.
1grnlwn
Re: Coal Experiment
« Reply #1 on: January 16, 2011, 06:49:24 PM »
My grandfather told stories of heating his house with stolen coal.  I suppose things haven't changed that much.
Re: Coal Experiment
« Reply #2 on: January 16, 2011, 08:45:00 PM »
No, it's not like that.  Employees of the coal docks are allowed a certain amount of coal per year.  Some sell it, some use it, some give it away.
However, if you go into the coal fields where these haul rails run for miles in these vacant valleys you'll find coal theiving going on.  They'll pry open the hopper door on a railroad car and the whole center of the load will fall out the sides.  Then everyone and their brother comes along and loads up on it.  Also, in extreme rural "poor" parts of eastern ky you'll see people and families digging coal out of the road benches where they've made highways.
1grnlwn
Re: Coal Experiment
« Reply #3 on: January 16, 2011, 10:19:37 PM »
I live in Illinois so we will be steelin coal soon!
rick n kristi
Re: Coal Experiment
« Reply #4 on: January 17, 2011, 11:30:07 AM »
Scott7m,
Glad to here you are experimenting too. My 1st coal purchased almost 1 month ago cost about $100 for 1000lbs. I'm still burning that load with wood and have given the smaller chunks to a neighbor who is hand firing a wood/coal stove. We both have experienced extended burn times. Looking forward to hear of your results!
Rick
Natures Comfort 325G
Still 038 magnum
Re: Coal Experiment
« Reply #5 on: January 17, 2011, 01:13:52 PM »
Now that I've figured out and solved the problem with my OWB, I can go back to using a bit of coal again.  Although recently I've been tossing in chunks of unsplit Bradford pear wood in sizes from 3" to 10" diameter.  That stuff gives me about 18 hour burn times on one load.  I can't imagine how long coal/Bradford pear would burn.
eco-extend
Re: Coal Experiment
« Reply #6 on: January 17, 2011, 03:14:52 PM »
remember guys put the coal on top of your wood only, if you put the coal directly on the grartes you will crack or warp them, coal is very hot for a long period of time just something id throw out to ya
Re: Coal Experiment
« Reply #7 on: January 17, 2011, 07:50:58 PM »
I burn coal directly on my grates without any issues. Heat Masters grates are easily replaced if I do have problems down the road.
Re: Coal Experiment
« Reply #8 on: January 17, 2011, 08:44:59 PM »
I've got several customers burning straight coal.  Not
heard a problem yet.
They sell coal here for $120 a ton, I heard another place sells it for $90 but
it's further away.
Re: Coal Experiment
« Reply #9 on: January 18, 2011, 06:04:34 AM »
I finally have my one ton dump truck on the road and I'm heading out this morning for a load of coal. I hope to buy enough to finish the year and most of next as well. Also I'm not going to have to unload it by hand when I get home!
tulenutn2o
  • OWF Brand: HeatSource1
  • OWF Model: Earth Energy 190
Re: Coal Experiment
« Reply #10 on: January 18, 2011, 06:13:03 AM »
I wish we could still get coal in Iowa. :(
PhinPhan
  • OWF Brand: WoodMaster
  • OWF Model: 4400
    • Outdoor Wood Furnace Info
Re: Coal Experiment
« Reply #11 on: January 18, 2011, 11:11:20 AM »
Other than coal getting very hot, are there any other risks of burning coal in an OWB?  I have a WM 4400 that is all boiler plate, what are the risks.
Pomeroy, OH
WoodMaster 4400
rick n kristi
Re: Coal Experiment
« Reply #12 on: January 18, 2011, 11:22:58 AM »
My 325G does not have grates; there are fire bricks spaced out along the bottom. I let the boiler burn down to embers before adding coal. I rake the embers out evenly on the bottom; place 2 6to8 inch green rounds on each side then shovel in the coal in the middle on top of the wood embers. Two scoop shovels is plenty, then fill with wood. At mid 20 highs and mid teen lows I can leave for 36 hours and come home to a warm house (thermostat at 60) 36 hours later. At 70 I can make 24 to 30 hours before needing to reload.
Still 038 magnum
Re: Coal Experiment
« Reply #13 on: January 18, 2011, 04:08:23 PM »
I've yet to see burning coal be a problem in a boiler surrounded by water.  Natures Comfort  boilers have water completely surrounding the jacket, even on the front.  The only time I can see it being a problem is that if you had a boiler that had no water perhaps in the back or front, and you had coal laying against it.  However, if you keep your coal where it should be there is little chane for problems as there is water just basically on the other side of the metal.  I don't know if any of you have ever experimented but you can take a cutting torch and you can't even burn a paper cup if it has water inside of it.  Now on old time wood stoves and outdoor furnaces that use air, you do run the risk of warping or distorting your stove.  There is no water surrounding the firebox and that allows the temps of the firebox metal to skyrocket.
I always have a good bed of coals/ashes and never worry about it warping my grates.  Heat wants to rise..  I'm not saying that it CANT warp your grates.  But with a little care and precaution I don't think you would ever do it.
My coal experiment is doing very well.  I've been cutting my wood fill back more and more.  I've basically putting in 20-30 pounds of coal each night, and I've cut my wood back to probably 1/3 of what I was burnign a few weeks ago.  I am getting solid 24 hour burns and when i go to fill the stove at night, it still has a huge bed of coals and the temp is still at 158.
Re: Coal Experiment
« Reply #14 on: January 18, 2011, 06:37:26 PM »
On another Coal experiment note:
I've got a customer burning coal in an NCB-250.  He's heating a 2800 sq foot house, a 2 story garage that measures out probably in the range of 2200 sq ft.  He's keepin the garage at 60 and his home on 73.  He's had the temp of his OWB set at 160 all season.   We checked the temps out of his register in the house and it was 122.  I said that was over-kill.  We dropped the temp on the stove  back to 145, temp out of the register is now 110-112, coal use is now now probably 1/3 of what it previously was.
