Author Topic: getting ready to make the door  (Read 7774 times)
beeman
  • OWF Brand: homemade
« on: January 17, 2011, 03:57:47 PM »
i could use some advice from the many talenet on this site how do you make a door that is adjustable  and a door lach
Re: getting ready to make the door
« Reply #1 on: January 17, 2011, 04:21:01 PM »
i could use some advice from the many talenet on this site how do you make a door that is adjustable  and a door latch
I kept mine simple, i never allowed for adjustment I made my hinge out of pipe and a 3/4 inch rod that fit snugly inside and made the hinge like a piano hinge all the way the full length of the door. i am in year 11 and there is no wear that is showing yet
others likely have more elaborate set ups but i like simplicity
beeman
« Reply #2 on: January 29, 2011, 07:21:08 PM »
do you have a close up picture of your hinges and door latch thanks for help
jackel440
« Reply #3 on: January 29, 2011, 08:06:29 PM »
Here is the linkto I believe page 5 on my build thread of how my hinges are made.
http://outdoorwoodfurnaceinfo.com/forum/index.php?topic=642.60
Mine are slotted to allow adjustment in and out for the shrinkage of the rope seal of the door.Plus to allow for a perfect fit of my door to the door frame opening.My latch is slotted so I can adjust it in and out to allow more or less pressure to be applied to the door.I also used studs to mount the hinge onto to allow the use of shims to align my door sideways.Worked out very nicely.good luck :thumbup:
New Holland LS170
24' Titan deckover gooseneck
96' Dodge Ram 2500 V10 4x4
Stihl 025
Stihl 038 Magnum
Stihl 041 AV
