Pages: 1 2 [3]
Author Topic: Show schedule for 2016  (Read 19944 times)
Re: Show schedule for 2016
« Reply #30 on: October 14, 2016, 06:23:43 PM »
How cold does the cooling side need to be?
« Reply #31 on: October 14, 2016, 09:58:39 PM »
They are cooling it with either well water or water out of a pond.
I thought if required I could just take a fairly large cooler of ice everyday to provide the cooling, or invest in a large number of heat sinks and have the fan blow air across those, design will have to be considerable different though than the videos.
Here is a full length video of everything one company is doing in Portugal with LTD stirlings, but they are using vegetable oil at 100-200C, our boilers produce around 90-95C? Hence need even better cooling to maintain a larger heat differential. Would really hate to have enough dry ice around for 4 days of cooling over Labor Day. Or, with a lower differential need even a larger displacement engine. Another interesting thing I’ve found is instead of a crankshaft to run the displacer a cam can be used instead to achieve a much longer dwell time of the displacer resulting in the working gas being in contact with the hot and cool sides longer which should increase efficiency.
https://www.youtube.com/watch?v=duuk_r--lqU
Back to my original thread as this is getting way too derailed.
http://outdoorwoodfurnaceinfo.com/forum/index.php?topic=8664.0
« Last Edit: October 15, 2016, 06:45:02 AM by mlappin »
Pages: 1 2 [3]
