Author Topic: Nother broken chain!!! :bash:  (Read 10985 times)
kommandokenny
  • OWF Brand: woodmaster
  • OWF Model: 4400
« on: February 21, 2016, 11:46:19 AM »
Broke two chains theses last couple of days.
Todays hit me in the shin.
026 with 18 inch bar... sthil chain.
Been using the saw for a few years,bought it used.
I have never broken a chain before, so I don't think it's that common.
I know the bar is a little long for the saw, but bar seems to be in ok condition.
Stuck the depth guide in and it's within specs [just. ]
Any ideas????
« Last Edit: February 21, 2016, 12:04:15 PM by kommandokenny »
PARRY SOUND ONTARIO
2012 RAPTOR
NORTON COMMANDO
H.D. ROAD KING
Sthil 026,038
Echo CS 310 [grandaughters]
SWISHER 22 TON
CANAM 850 tracked
GREAT DANE X 3
kommandokenny
  • OWF Model: 4400
Re: Nother broken chain!!! :bash:
« Reply #1 on: February 21, 2016, 12:03:22 PM »
http://www.arboristsite.com/community/threads/ever-had-a-chainsaw-chain-break.117594/
Read this and most people that break chains,, hit something.
That, or they wiggle it when stuck,, and weaken it.
I may have got the old chain stuck and wiggled it,,but not the newer one,,,that I remember.
Chain break happens more than I thought,,though.
Taking it into Sthil dealer and see what they say.
« Last Edit: February 21, 2016, 04:02:29 PM by kommandokenny »
PARRY SOUND ONTARIO
2012 RAPTOR
NORTON COMMANDO
H.D. ROAD KING
Sthil 026,038
SWISHER 22 TON
CANAM 850 tracked
GREAT DANE X 3
« Reply #2 on: February 21, 2016, 12:05:08 PM »
How were they re-sharpened? I have seen where someone set the sharpener too deep and hit the link and caused chains to break.
BoilerHouse
  • OWF Brand: Home Built
« Reply #3 on: February 21, 2016, 12:28:31 PM »
I don't know if a worn sprocket could cause a chain to break, but Stihl (at least in my manual) recommends replacing the sprocket every 2nd chain.
Muskoka, Ont
kommandokenny
  • OWF Model: 4400
« Reply #4 on: February 21, 2016, 03:07:08 PM »
Thanks
I sharpen the chains by hand, only did the new one once.[it broke today]
Looking into the sprocket change for sure.[good call]
Taking it in to dealer tomorrow.
Gonna switch to 16 inch bar also.
« Last Edit: February 21, 2016, 04:04:36 PM by kommandokenny »
PARRY SOUND ONTARIO
2012 RAPTOR
NORTON COMMANDO
H.D. ROAD KING
Sthil 026,038
SWISHER 22 TON
CANAM 850 tracked
GREAT DANE X 3
hoardac
  • OWF Brand: Heatmaster G-200
« Reply #5 on: February 21, 2016, 08:01:28 PM »
I have had a few chains break over the years. One was jammed, another hit an I beam at work, the third one was for no apparent reason I put a few new links in it and it never broke again.
kommandokenny
  • OWF Model: 4400
« Reply #6 on: February 22, 2016, 11:18:39 AM »
Got back from the Sthil store.
Tech did not know for sure, why chains broke.
He agreed changing the drive sprocket was a good idea.
It was hacked up a bit.
So I got a new sproket and chain for my 18 inch bar ,,and a 16 inch bar and chain.
I'll let you know how it goes.
PARRY SOUND ONTARIO
2012 RAPTOR
NORTON COMMANDO
H.D. ROAD KING
Sthil 026,038
SWISHER 22 TON
CANAM 850 tracked
GREAT DANE X 3
Bud Man
  • OWF Brand: P&M
  • OWF Model: BL 2840
« Reply #7 on: February 23, 2016, 08:55:12 PM »
Keep us updated. Recently, I put on a chain I had sharpened and it would lock-up either while coming up on RPM or going down. Called the dealer and he said if a chain gets thrown it can booger-up the guides and cause it to lock-up. My wife did have a chain throw off a while back so that must have been the one.
kommandokenny
  • OWF Model: 4400
« Reply #8 on: February 24, 2016, 06:19:21 AM »
What do you mean by "guides"??
I did have a lot of chain freeze ,it was from snow getting sucked into the saw body.
This happened prior to the chains breaking.
I'll post any new info,, but if anyone else has input......... great!
PARRY SOUND ONTARIO
2012 RAPTOR
NORTON COMMANDO
H.D. ROAD KING
Sthil 026,038
SWISHER 22 TON
CANAM 850 tracked
GREAT DANE X 3
fireman69lfd
« Reply #9 on: February 24, 2016, 01:52:58 PM »
I have never broken a chain, but I have had a chain throw and it messed up the guides so it wouldn't move on the saw. The guide is what keeps the chain on the bar. Hard to see that their bad too, not very obvious.
Good luck
Russ
Near Okemo Mtn. Ski area Vermont
kommandokenny
  • OWF Model: 4400
« Reply #10 on: February 24, 2016, 02:23:00 PM »
So there is a guide bar ["the bar"] then there's the guides?
I take it the guides are the two flaps of thin metal in the drive sprocket compartment?
Mine look good.
Gotta get out and try the new 16 inch bar and chain sprocket.
Got a blizzard coming in,, so let you know in a couple of days
PARRY SOUND ONTARIO
2012 RAPTOR
NORTON COMMANDO
H.D. ROAD KING
Sthil 026,038
SWISHER 22 TON
CANAM 850 tracked
GREAT DANE X 3
fireman69lfd
« Reply #11 on: February 24, 2016, 06:50:57 PM »
Kommandokenny, I apologize that I used some wrong terminology. The guide that I'm referring to is called the drive link [after looking it up]. It rides down in the bar groove.
Sorry about that. Good luck
Russ
kommandokenny
  • OWF Model: 4400
« Reply #12 on: February 24, 2016, 07:16:39 PM »
No problem Fireman.
I see what the drive links are.
Don't think that was my issue, as one chain was near new.
I'm examining the bar further and noticed its uneven on one side.
Apparently if the guide bar does not stand up by itself on a flat surface, it should be replaced.
Mine stands on one side but not the other.
I'll see if I break a chain with the new bar,if not, could of been the old bar???
PARRY SOUND ONTARIO
2012 RAPTOR
NORTON COMMANDO
H.D. ROAD KING
Sthil 026,038
SWISHER 22 TON
CANAM 850 tracked
GREAT DANE X 3
