Author Topic: lets start a OWB "WHAT IF THREAD" TIPS  (Read 10133 times)
adamant
    • my pic site
« on: October 26, 2008, 08:16:00 AM »
lets start a thread about "what if this happened to your outside wood boiler"
on another forum i seen a  posted a tip: if the damper failure (solenoid) place a 16d nail in the damper to give it enough air to keep the temps up until the solenoid can be replaced.
what other tips can you share?
ant
gas forced hot air/gas hot water
buck supreme insert 2/14/1991 to 2/21 2007 (rip)
LOPI freedom bay insert. (present)
central boiler classic 6048
NEW JERSEY
what we do on the weekends
http://community.webshots.com/user/adamant117
http://adamant.pictiger.com/
charlie
Re: lets start a OWB "WHAT IF THREAD" TIPS
« Reply #1 on: October 26, 2008, 06:16:37 PM »
That's a great idea. In a pinch wood boiler survival! Heating outside the book! This makes thinkers! Sounds good! :thumbup:
woodmaster 434 since 2002, 612 gal. storage stss; super splitt;stihl ms360.
adamant
    • my pic site
« Reply #2 on: October 29, 2008, 07:34:21 PM »
alright guys ..you got me thinking ...i bought a extra Circulator pump taco 0014 from granger for $210 delivered. i could have got the replaceable cartridge contains all of the moving parts so you can service it easily instead of replacing the entire unit. i did not want to take a chance of my unit being down without a pump because i am using water in my system . a line would freeze by the time i could get a pump.
NEW JERSEY
ckbetz
« Reply #3 on: November 01, 2008, 05:22:43 AM »
I wired a plug on my OWB and plug it in instead of wiring it directly to an electrical box.  This way if the power goes out I can easily plug it into a generator or even an inverter.  Remember that most of those pumps draw around an amp of current which is about as much as a 100 watt lightbulb so there should be no reason you can't keep it running during an outage.  Those of us with a direct plumbed system can also run the inside of the home the same way.
Pomeroy, Ohio
