Author Topic: water to water exchangers  (Read 8068 times)
robdogtn
  • OWF Model: BL 34-44
« on: September 30, 2016, 12:25:03 PM »
quick question on installation.  Does it matter if I swap the inputs, ie, instead of going in A1 and coming out A2 for the hot water, can I go in A2 and out A1?  I wouldn't think it would matter if the insides of the exchanger are the same.
If not no big deal just trying to save some labor and rework on my layout.
Portage & Main BL 34-44
Re: water to water exchangers
« Reply #1 on: September 30, 2016, 09:30:33 PM »
Input and output doesn’t matter as long as you have a cross flow, IE if your boiler water comes in one end you want your domestic water to enter the other end and exit the end your boiler water enters, this gains the most heat transfer.
fireboss
« Reply #2 on: October 01, 2016, 06:20:40 AM »
Make sure it's plenty big enough! Bigger is better! And plan on putting some boiler drains so you can back flush it  to clean it if you have to!
braveblaster
  • OWF Model: 7500
« Reply #3 on: October 29, 2016, 05:31:10 PM »
Am sure you are 100% correct but the wording got me lost (not your fault) could you draw something to explain this so I can get it right? Thanks
« Reply #4 on: October 29, 2016, 05:35:34 PM »
You just want flow going opposite directions.
« Reply #5 on: October 30, 2016, 04:20:30 AM »
Braveblast - I hope this helps to visualize what they are saying.  Roger
« Reply #6 on: October 30, 2016, 04:24:54 AM »
well done Roger!
« Reply #7 on: October 30, 2016, 04:44:31 AM »
well done Roger!
Thanks.  I'm learning from a good teacher.
For some people, me included, pictures are worth more than 1000 words.  Roger
Revx1000
  • OWF Brand: P/m
  • OWF Model: Ultimizer
« Reply #8 on: October 31, 2016, 06:58:45 PM »
He is a pic of what I did , better to have your return line going back to the boiler on the bottom  less chance of sediment dropping off in the exchanger
