Pages: 1 2 [3]
Author Topic: G200 door leaking  (Read 23986 times)
Re: G200 door leaking
« Reply #30 on: December 30, 2016, 03:18:51 PM »
I also talked to my local dealer about the "Smokin' Swoosh" - she did some research and came up with this response from the oracle... "Yes, I've had mine do that too if it is loaded up with dry "baked" wood and the nozzle is a little choked. The wood gas ignites sporadically and "chuffs".  And the  baked wood gasifies very quickly and floods the nozzle with wood gas.  Usually digging a small hole through the coal bed with poker will send an even steady amount of wood gas / oxygen into the horseshoe brick."  Who'd have thunk it?
So, as RSI suggested, this was, in fact, two separate problems and the poor door seal at bottom latch was simply highlighting it.
You guys rock!
I’m thinking P&M was known for huffing like you described, but the nozzles on those were  a little easier to plug than G series.
fireboss
« Reply #31 on: December 30, 2016, 05:24:43 PM »
I think that tool is a crows foot that's what I would call it!
aarmga
  • OWF Brand: Nature's Comfort
  • OWF Model: NCB-250
  • Central Wisconsin
« Reply #32 on: January 23, 2017, 12:10:52 AM »
I know exactly what you are talking about schoppy, I just went through it myself with my 400, the hinges are difficult to adjust with the weight of the door on it! Because I'm such a life hack, here is my solution.
Start by wrapping a long ratchet strap through the door handle and completely around the boiler (use cardboard or rags to keep from scratching the paint with the metal portions of the stap) hook the ends of the strap together and loosely tighten the strap, place a small car scissor jack between the door and strap
( again use a softener) tighten the screw jack a bit so it will put pressure on the door inwards, now loosen the 4- 9/16 nuts that adjust the hinge side of the door, you should see the hinge adjustments move, unlatch the latch side and center the door on the jamb now take a few more turns on the screw jack, this will force the door onto the jamb, adjust your hinge and tighten them, dismantle the hack and move over to the latch side of the door. The latch side is a 3/4 inch acorn nut on each,loosen them and tap the bolts inward about 1/8 inch at a time, re tighten and try the latches, they should be tight enough to show some resistance without being hard to operate. With the doors all closed and the bypass open, fan operating you should not be able to hear any leakage around the door gasket. You will still have some residual liquid in the gasket that will drip out when the door is operated but it will subside and dry up after using the door a few times. The guys at the office can get you some spray bombs of the original color or if I have a chance perhaps I can find the paint color codes that I got from NAPA to paint  the bus, it is an almost perfect match, best of luck and let us know how you make out!
It's really too bad there aren't any dealers around the Wisconsin area like you slim. Me and my family including my in laws would all have purchased through you.  We have absolutely zero dealer support around here. I can't even get a phone call returned.  When I bought my stove a couple years back I was promised 24-7/365 service (not free obviously but incase of emergency I'd have someone to fall back on) but now since the EPA has Stepped in I don't even get a phone call back yet alone an answer on a Wednesday at 11am.
Stihl 211 - 16"
Remington Rodeo Pro - 20"
Stihl 661r magnum - 36"
SpeeCo 22 Ton Honda splitter
JD 1025r with FEL
aarmga
  • Central Wisconsin
« Reply #33 on: January 23, 2017, 12:26:43 AM »
Exactly what I call it too.  Crows toe or crows foot
Stihl 211 - 16"
JD 1025r with FEL
Pages: 1 2 [3]
