Author Topic: Pump rebuild  (Read 9336 times)
freefour
  • OWF Model: H4
Pump rebuild
« on: December 01, 2016, 10:15:30 AM »
Hey Guys,
A friend of mine had a pump go out of his Hardy H4.  It's a Taco pump.  He was wondering if there are rebuild kits available for them?  He bought a new one but would like to rebuild this one for a backup.
I have no idea but thought I'd ask on here.
Re: Pump rebuild
« Reply #1 on: December 01, 2016, 11:08:48 AM »
Yes you can rebuild them but the cartridge is typically only $10-20 cheaper than a completely new circ.
freefour
  • OWF Model: H4
Re: Pump rebuild
« Reply #2 on: December 05, 2016, 01:27:29 PM »
Thanks slimjim!
Do you know where I could price one for him on the net?
Re: Pump rebuild
« Reply #3 on: December 05, 2016, 04:29:09 PM »
I do very little business via the internet, I like to be able to look a man in the eye, expect a fair deal and get good quality / service with a personal hand shake.
juddspaintballs
Re: Pump rebuild
« Reply #4 on: December 05, 2016, 07:10:28 PM »
PexSupply.com
PexUniverse.com
Amazon
to name a few
Re: Pump rebuild
« Reply #5 on: December 05, 2016, 07:45:25 PM »
What model pump is it?
freefour
  • OWF Model: H4
Re: Pump rebuild
« Reply #6 on: December 08, 2016, 12:53:13 PM »
Taco 009 I believe
Re: Pump rebuild
« Reply #7 on: December 08, 2016, 03:34:46 PM »
Taco 009 I believe
Might even check Menards, I know I remember seeing 007’s there once.
Re: Pump rebuild
« Reply #8 on: December 08, 2016, 03:43:35 PM »
Ebay is probably the cheapest. Do you know if you really need an 009? If if you don't have a lot of restriction you might be better off with a 0015 or 15-58 that is cheaper for the whole pump than repairing the 009.
shepherd boy
  • OWF Model: C375
Re: Pump rebuild
« Reply #9 on: December 08, 2016, 05:25:08 PM »
Hardy uses a 009 stainless because they don't always use water treatment with the 304 stainless stove. So they match a stainless pump with it.  They also  ran a lot of four line 3/4 pex and needed a high head pump to push water in that line. If this is the case you may want to rebuild your pump. $121 on amazon.
Let the youngin's have it
 Gettin' old and lazy
Re: Pump rebuild
« Reply #10 on: December 08, 2016, 11:12:01 PM »
If it is 3/4" pex then then 009 is probably the right pump.
freefour
  • OWF Model: H4
Re: Pump rebuild
« Reply #11 on: December 12, 2016, 01:54:21 PM »
Yes, I looked over the weekend.  It's a 009.  Yes, it's a Hardy with 3/4" lines.  He a good friend and I would like to rebuild it for him if it's not too difficult.  Is this what I need?
https://www.amazon.com/Taco-009-022RP-Circulator-Replacement-Cartridge/dp/B003EUVFR0/ref=sr_1_4?ie=UTF8&qid=1481576008&sr=8-4&keywords=taco+009+replacement+cartridge
Or here's one even cheaper on eBay:
http://www.ebay.com/itm/Taco-009-Bronze-Replace-Cartridge-For-Outdoor-Wood-Furnace-Maintenance-5800007-/141981966029?hash=item210ec8decd:g:Y~sAAOSw5HJXKkZn
Not sure what it says "Bronze".  It's a stainless pump.  Can anyone let me know on what is involved with doing the rebuild?
Thanks!
« Last Edit: December 12, 2016, 01:57:10 PM by freefour »
Re: Pump rebuild
« Reply #12 on: December 12, 2016, 02:27:22 PM »
Is it a bronze or cast iron pump? It appears that they use a different cartridge.
This does not replace the electrical windings so you need to make sure they are good. It should be pretty easy to replace the cartridge. Just remove the 4 bolts that attach the heat and take apart. Then you should be able to pull out the bad cartridge and put in the new one.
shepherd boy
  • OWF Model: C375
Re: Pump rebuild
« Reply #13 on: December 12, 2016, 04:40:20 PM »
I think the stainless and cast use the same cartridge. Either one looks to me to be stainless.
