Author Topic: 40 drops  (Read 12942 times)
sabercat
  • OWF Model: 5036
40 drops
« on: December 06, 2016, 06:42:21 PM »
If I'm at about 40 drops on the nitrate test what do I do. Do I drain some out and refill? I have soft water available. Thanks
Re: 40 drops
« Reply #1 on: December 06, 2016, 08:36:18 PM »
How old is the test kit?
boilerman
Re: 40 drops
« Reply #2 on: December 06, 2016, 09:48:17 PM »
Look for a date stamp on your permanganate bottle (the purple stuff) it is only good for 2 years from that date. It may give false high readings when it gets older. Nitrite levels do not go up on their own unless more corrosion inhibitor has been added.
sabercat
  • OWF Model: 5036
Re: 40 drops
« Reply #3 on: December 07, 2016, 04:44:07 AM »
Look for a date stamp on your permanganate bottle (the purple stuff) it is only good for 2 years from that date. It may give false high readings when it gets older. Nitrite levels do not go up on their own unless more corrosion inhibitor has been added.(/quote)
I will check tonight, but ya its probably older then 2 yrs. Thanks
adamant
    • my pic site
Re: 40 drops
« Reply #4 on: December 07, 2016, 06:55:18 PM »
I religiously purchase a new test kit every two years.. this year I had to purchase a new one ..old one says April 2015 and it already went bad. Just got one off e bay and I am at 17 drops. I am storing this one in the house.. not at the boiler
gas forced hot air/gas hot water
buck supreme insert 2/14/1991 to 2/21 2007 (rip)
LOPI freedom bay insert. (present)
central boiler classic 6048
NEW JERSEY
what we do on the weekends
http://community.webshots.com/user/adamant117
http://adamant.pictiger.com/
sabercat
  • OWF Model: 5036
Re: 40 drops
« Reply #5 on: December 08, 2016, 04:57:38 AM »
Did you purchase the whole kit or just the permanganate?
sabercat
  • OWF Model: 5036
Re: 40 drops
« Reply #6 on: December 10, 2016, 07:46:12 PM »
well I got some new permanganate, now its at 5 drops, lowest every. So is that good or bad?
duramax
  • OWF Brand: central boiler
  • OWF Model: 1450
Re: 40 drops
« Reply #7 on: December 15, 2016, 02:56:11 PM »
did you get the bottle from central boiler or some other place. If you are doing the test by their method you will need to treat the water to get it back up.  I had to buy a new bottle this year because mine was expired and was black .
Central Boiler E 1450 Homemade 13 hp wood splitter, Kubota L 3800 tractor
boilerman
Re: 40 drops
« Reply #8 on: December 15, 2016, 09:51:00 PM »
If your test is accurate you will need to add 1/2 container of CB corrosion inhibitor to put you back into range of 15-30 drops
sabercat
  • OWF Model: 5036
Re: 40 drops
« Reply #9 on: December 16, 2016, 09:42:13 AM »
Yes got it from the local CB dealer
sabercat
  • OWF Model: 5036
Re: 40 drops
« Reply #10 on: December 16, 2016, 09:43:14 AM »
OK, will do, then in a couple days I'll redo the test. Thanks
sabercat
  • OWF Model: 5036
Re: 40 drops
« Reply #11 on: December 29, 2016, 07:13:53 AM »
put half a bottle in, now at 16 drops.
