Author Topic: BL 28-40 blower fan making some noise and float level float.  (Read 71036 times)
Crow
  • OWF Model: BL 28-40
  • Eastern Ontario
Re: BL 28-40 blower fan making some noise and float level float.
« Reply #15 on: May 24, 2019, 05:17:03 AM »
They have an updated float available.
Super44
  • OWF Model: Ultimizer BL 2840
« Reply #16 on: May 31, 2019, 07:03:23 AM »
I will ask to make sure I am getting the updated one.  Thanks!
Super44
« Reply #17 on: October 28, 2019, 05:37:20 PM »
I got the new float and is has a little different neck set up on it.  Started the boiler today and everything seems OK so far.  Only issue is a wood pile that needs a bunch more wood in it.  Come spring and shut down a few more shark bites will be replaced.
blmike
  • OWF Brand: portage & main
  • OWF Model: bl2840
« Reply #18 on: November 09, 2019, 07:13:54 AM »
The float will fill with water ,and needs to be replaced .I keep a spare now.
Super44
« Reply #19 on: November 11, 2019, 09:41:10 AM »
The old float cracked where the threaded rod went into it.  I maybe should have picked up a spare?
Super44
« Reply #20 on: April 27, 2020, 07:28:03 PM »
Made it thru the winter with no issues and shut it down today.  I have a few more shark bites to replace before the next first fire but other than that it was a trouble free winter as far as the boiler goes.
Super44
« Reply #21 on: October 21, 2020, 07:29:00 AM »
Replaced all but a couple shark bites during the summer.  Fired it up 10/20/20 and it went pretty well as the couple remaining shark bites only dripped a bit until they got warm.  The last ones are the ones that hook up to the heat exchangers so next summer I will pull them out and solder on something better.  Just need to come up some kind of a coupler so if need be I can pull the heat exchangers without cutting PEX to do it. Off to a pretty good start. :)
Super44
« Reply #22 on: May 01, 2021, 08:26:38 PM »
5/1/21 I shut "Little Smokey" down for the season.  I replaced all but a couple "Shark Bites" and had almost no drips while cooling down for this summer.  This last winter was a very trouble free season!!  Now to get to work on next seasons wood pile and there is a new bull at the farm that I need to spend some time with to know how he thinks.  So far all he seems interested in are where the cows are.  Go figure!! ;D
« Reply #23 on: May 06, 2021, 04:35:35 AM »
I've seen those sharkbites drip when shutting down too. Good call on swapping them out.
Super44
« Reply #24 on: March 27, 2022, 07:02:17 PM »
It seems my water lever float has cracked at the neck like the one before it.  Should have gotten a spare or two.
Super44
« Reply #25 on: January 27, 2023, 08:03:13 PM »
Burning a fair amount of iron wood this winter.  If dry it burns very nice. :)
Super44
« Reply #26 on: June 01, 2023, 05:20:31 PM »
Had a trouble free season.  I learned how to shut it down for a week due to warm weather and start it up in a couple hours. There is a tiny air leak someplace and the fire just keeps smoldering if I throw in a chunk or 2 every couple of days.  Only a couple shark bites still in the system only because they have not leaked like all the rest.   :thumbup:
Super44
« Reply #27 on: October 27, 2023, 02:38:15 PM »
Fired up the boiler today with no issues.  Vahooo!!
Super44
« Reply #28 on: October 20, 2024, 07:25:39 PM »
We had a 3 day cold spell, ran the boiler for those three days and shut her down with no leaks.  This is getting better each heating season.  Hope things are good!
Super44
« Reply #29 on: October 31, 2024, 10:05:13 AM »
Ran the boiler a couple days twice this fall to protect the lines from freezing and put a little heat in the work shop.  Today I opened all the valves and plugged in both pumps and had only a few drops of water leak from  the valves as I turned them.  I think we are on for the rest of the heating season.  :)
