Author Topic: AC off of OWB??  (Read 22002 times)
Re: AC off of OWB??
« Reply #15 on: April 18, 2011, 11:06:18 PM »
 However you do it you need to be really sure that you are not getting moisture down into the fan and electronics. I doesn't take long to start having problems if that happens.  I have a customer who says he is going to try this, I am interested in how it works.
bruey
Re: AC off of OWB??
« Reply #16 on: April 22, 2011, 06:47:21 PM »
thats what i thought, water problem but this guy swears it works and he does not have a moisture problem, as far as the pipe a friend said i will need about 1200 feet,  and pex is cheep , going to dig about 7 to 8 feet down and do a loop design, i went on line for geothermal and it shows a vast amount of information for underground and water installs. i am going up to see his unit this summer and will report.
Newrichmond, Ohio
Re: AC off of OWB??
« Reply #17 on: April 22, 2011, 07:08:10 PM »
You are going to try pumping water through 1200' of pex? What size are you going to use? 1" won't be much volume.
bruey
Re: AC off of OWB??
« Reply #18 on: April 22, 2011, 07:16:14 PM »
yes on the pump, yes on the 1"
Newrichmond, Ohio
Re: AC off of OWB??
« Reply #19 on: April 22, 2011, 07:19:54 PM »
Have you looked at the head loss on 1200' of 1" pex? You won't have much water moving.
bruey
Re: AC off of OWB??
« Reply #20 on: April 22, 2011, 07:27:13 PM »
it for sure wont be a wood stove pump and also the indoor fan will run slower and longer than that of normal ac, this is what i have been told, we shall see
Newrichmond, Ohio
Re: AC off of OWB??
« Reply #21 on: April 22, 2011, 07:40:17 PM »
It doesn't matter what kind of pump, it will be slow. I thought the fan ran faster for AC.
If you are going to stay with 1" pex and if possible, I would split it into 2 600' runs and put them in parallel.
How much are you paying for the pex? 1200' won't be that cheap. How much does it cost to run your AC?
