Author Topic: Should I drain water out of my boiler at the end of burning season???  (Read 18697 times)
Re: Should I drain water out of my boiler at the end of burning season???
« Reply #15 on: February 14, 2017, 05:58:20 PM »
Emailed Heatmaster- They said they use an electric meter with probes.
No more than 4,000 micromhos is what you want. 1-2,000 is more normal.
Too high and you can get electrolysis pitting.
« Last Edit: February 15, 2017, 06:33:43 AM by E Yoder »
aarmga
  • OWF Brand: Nature's Comfort
  • OWF Model: NCB-250
  • Central Wisconsin
« Reply #16 on: February 14, 2017, 09:37:10 PM »
Good to know. I understand that completely.  Problem is, I have no way to get to the water to test it with probes.
Stihl 211 - 16"
Remington Rodeo Pro - 20"
Stihl 661r magnum - 36"
SpeeCo 22 Ton Honda splitter
JD 1025r with FEL
« Reply #17 on: February 14, 2017, 10:09:49 PM »
No more than 4,000 micro-ohms (sp.?) is what you want. 1-2,000 is more normal.
Really? I would think there’d be  a procedure far as how far apart to hold the probes etc.
shepherd boy
« Reply #18 on: February 15, 2017, 02:02:19 AM »
I have a continuity meter somewhere, used it to check mineral content in greenhouse fertilizer mix. It's a simple machine you fill with about three tablespoons mix and and it gives you a reading. Probes are preset in unit. Think it was called an EC meter. Maybe not the same but it measured salts in the mix by using a continuity reading. I remember we were shooting for a 2500 reading and the unit went from 0-5000.
Was researching EC meters, there are a lot out there and cheap compared to 20 years ago when we used them. Be a nice thing to have for a periodic check on boiler water.
« Last Edit: February 15, 2017, 05:02:00 AM by shepherd boy »
Let the youngin's have it
 Gettin' old and lazy
« Reply #19 on: February 15, 2017, 06:32:48 AM »
Quote
Drain some out into a cup?
Quote
I'm not sure what kind of meter they have. Would have a preset distance between probes I would think. There are EC meters all over Amazon.
This would be measuring very very low levels of conductivity so I'm not sure if a fertilizer EC meter would read it? The water test results I looked at were measured in "micromhos". I wrote "ohms" before and that isn't correct, I think.... Makes my head swim.
From Wikipedia-
The siemens (SI unit symbol: S) is the unit of electric conductance, electric susceptance and electric admittance in the International System of Units (SI). Conductance, susceptance, and admittance are the reciprocals of resistance, reactance, and impedance respectively; hence one siemens is equal to the reciprocal of one ohm, and is also referred to as the mho.
So that's why I send it off to Heatmaster to test!  :D
« Reply #20 on: February 15, 2017, 10:15:41 AM »
Quote
Quote
From Wikipedia-
 :post:
