Author Topic: CB prim. air intake  (Read 8367 times)
the trailmaster
  • OWF Brand: CENTRAL BOILER
  • OWF Model: 2400
CB prim. air intake
« on: March 06, 2017, 04:49:12 AM »
My E-2400 is in the fifth season with only a few problems, however I've just ordered the primary air intake elbow.  The present unit has rotted away and developed a hole in the bottom, which I put tape on to control air intake.  Anyone else have this problem, I'm assuming this is from the repeated creosote  build up which I clean once a month..  Thank you
Trailmaster  Plymouth NH
Re: CB prim. air intake
« Reply #1 on: March 06, 2017, 06:16:36 AM »
Anywhere you have mild steel and continuous moisture that problem will tend to happen. I'm not very familiar with that particular model but my guess is it'll do it again unless it's stainless.
aarmga
  • OWF Brand: Nature's Comfort
  • OWF Model: NCB-250
  • Central Wisconsin
« Reply #2 on: March 06, 2017, 11:20:28 PM »
Water isn't getting in there by chance is it?
Stihl 211 - 16"
Remington Rodeo Pro - 20"
Stihl 661r magnum - 36"
SpeeCo 22 Ton Honda splitter
JD 1025r with FEL
Roger2561
« Reply #3 on: March 07, 2017, 03:46:13 AM »
Trailmaster - I had to swap mine out for a new one on my 1400 after last season.  It had rotted through.  Like you, mine accumulates creosote, even after cleaning it monthly and it still rotted through.  When I can get my hands on some stainless steel, I plan on making one and replacing the mild steel one.  Roger
CB Classic Edge 550 HD
JD LX277AWS
Stihl 021
Stihl MS 311
2012 Honda Goldwing GL1800
New Hampshire
hoardac
  • OWF Brand: Heatmaster G-200
« Reply #4 on: March 08, 2017, 06:01:59 AM »
If you replace it you could paint the inside of the new one with a good hi temp enamel frame paint a couple of times to keep it from degrading as fast.
the trailmaster
  • OWF Model: 2400
« Reply #5 on: March 08, 2017, 04:41:36 PM »
Thank you all for the comments and advice.  I will give it a couple of coats of the stove paint before I install.  Thanks again, you folks all have such great knowledge, what a great  resource.  Trail master!!!
stryker
  • OWF Model: CL 6048, ECL 3200, Maxim M255PE
« Reply #6 on: March 08, 2017, 06:41:47 PM »
Hi everyone. I am new to this site. I am a central boiler dealer in Ohio. I don't claim to know everything but I will try to help out if I can.  Central boiler does offer a stainless steel primary elbow. Check out our site at Ohiowoodfurnaces.com and go to the parts at the top of the page. Insert part number 1200487. Make sure to read the description to make sure it will work for your furnace.
boilerman
« Reply #7 on: March 08, 2017, 09:03:21 PM »
Welcome to the forum Stryker. Yes the stainless replacement primary elbow that CB offers is the answer.
« Reply #8 on: March 09, 2017, 03:25:38 AM »
Welcome too. Glad to see people are able to register. I couldn't til I contacted mlappin.
Roger2561
« Reply #9 on: March 09, 2017, 03:49:34 AM »
stryker - Welcome and thanks for the info on the stainless elbow for the CB units.  I'll be checking with my dealer to see if he has them in stock.  Roger
JD LX277AWS
Stihl 021
Stihl MS 311
New Hampshire
