Author Topic: School me on assessing efficiency.  (Read 13977 times)
Re: School me on assessing efficiency.
« Reply #15 on: March 09, 2017, 05:25:59 AM »
You'd be amazed if you tried a downdrafter. My wood consumption dropped dramatically. And the new ones are very easy to use. No brushing tubes, etc.
 :post:
terpjr
  • OWF Brand: Woodmaster
  • OWF Model: 4400
« Reply #16 on: March 09, 2017, 07:12:28 AM »
Lol...my 30 degree temp problem was due to inaccuracy in my thermometer.
It was reading 30 degrees lower in the basement than it was at the furnace...send AND return (lol).
Steve Terplak - Upstate NY
Woodmaster 4400
Husqvarna 562xp, 460 and 261
Massey Ferguson 165, 265, 1080, 40B backhoe, Landini 105 and JD 450B dozer.
Homemade 3pt hitch splitter.
Smokeless
  • OWF Brand: HeatMaster ss.
  • OWF Model: G-100, 200,400
    • PCWoodBoilerSystems
« Reply #17 on: March 13, 2017, 07:10:02 PM »
Hello terpjr
  You have a really good question there.  I'm not a fan of infra red thermometer either.  They Work good on engine exhausts to check individual cylinder output temps. And eng temps. Yes the temp wells are very good and that is what I put on all my furnaces.
   It is important to make sure your heat exchanger is set up to counter flow the water ⏫⏬ !!
  Assessing efficiency. Can be done but it needs to be broken down into compartments,
 The btu requirements for the house or heat load. (Will change with temperature of course).
 Btu loss to the house. (Underground pipe type and size. )
 The efficiency of the heating unit. I like MLappins analysis on wood consumption.
    if the house is comfortable and warm all winter. And the boiler is at 180deg F  are you comfortable with cutting and handling all the wood that is not going to your house.
 I am in the Albany area often and would stop in to look at your system.
Or you could stop up and have a look at the G-200 in action. I'm just above Saratoga.
 I have to go to freehold NY to do a heat exchanger set up. That was done wrong. So I will be going by that area. You can call me. Or pm me.
Signature:
aarmga
  • OWF Brand: Nature's Comfort
  • OWF Model: NCB-250
  • Central Wisconsin
« Reply #18 on: March 14, 2017, 10:27:00 PM »
Excuse me for reading that wrong.  Even after you explain it here, still sounds wrong!
If u take temps at the stove and in the basement they are the same if you use the same  infrared temp gun... is that what I should be understanding?
My temp gun is within 2 degrees of my inline thermometer.
Stihl 211 - 16"
Remington Rodeo Pro - 20"
Stihl 661r magnum - 36"
SpeeCo 22 Ton Honda splitter
JD 1025r with FEL
