Author Topic: Which test kit  (Read 7960 times)
aarmga
  • OWF Brand: Nature's Comfort
  • OWF Model: NCB-250
  • Central Wisconsin
Which test kit
« on: March 31, 2017, 04:31:52 PM »
Would any of these test kits work for my outside wood burner?  They all test what I need to test but I'm not sure if the range of nitrates goes high enough. They only claim 50ppm.  If not where can I get the right test kit for me?
Stihl 211 - 16"
Remington Rodeo Pro - 20"
Stihl 661r magnum - 36"
SpeeCo 22 Ton Honda splitter
JD 1025r with FEL
Re: Which test kit
« Reply #1 on: March 31, 2017, 06:11:18 PM »
Maybe check with woodboilersolutions.
Re: Which test kit
« Reply #2 on: March 31, 2017, 06:55:36 PM »
Wood Boiler Solutions is who makes the kits that Nature's Comfort uses. They are located in Waupun.
Re: Which test kit
« Reply #3 on: March 31, 2017, 09:19:05 PM »
That was gonna be my suggestion. Both test kits you show are for drinking water, not boiler water.
I picked up the one on the left from Menards just for sh*ts and giggles. Iron, copper, lead, hardness were all at zero with the test for bacteria and pesticides being negative. Feel pretty good about the new water softener, I have a tritiation kit for testing hardness, at 38 grains out of the drinking water tap at the sink, at 0 out of the regular tap at the sink.
You really need a kit for boiler water, it will test at much higher levels of nitrates and might cover a few other things as well.
« Last Edit: March 31, 2017, 09:24:20 PM by mlappin »
aarmga
  • Central Wisconsin
Re: Which test kit
« Reply #4 on: April 01, 2017, 08:23:55 AM »
Waupun isn't too far from me. ill check that out!  Thanks!
Stihl 211 - 16"
JD 1025r with FEL
