Pages: 1 [2] 3
Author Topic: screw cone splitter  (Read 40838 times)
Re: screw cone splitter
« Reply #15 on: April 27, 2011, 09:07:30 AM »
How much do you want for it?
Guru
    • Mike's Advanced Heating
« Reply #16 on: April 27, 2011, 09:47:33 AM »
$100 will take it.
Mike
Nature's Comfort Territory Manager
Caro MI
http://www.mikesadvancedheating.com/
« Reply #17 on: April 27, 2011, 10:24:21 AM »
rosewood
« Reply #18 on: July 25, 2011, 08:32:12 PM »
Haven't checked site in a while,but Im still on the cone kick! Got a friend who might be able to get me a hydraulic auger set up. So been holding off on buying cone till I get that. Also recently added mini excavator  to toy box ,has extra plummed hyd and quick coupler so will be a easy build. With temps over a 100 yesterday who wants to think about wood.
« Reply #19 on: July 25, 2011, 09:31:20 PM »
I put one together with a stickler cone and hydraulic wheel motor. I am disappointing with the way it works. Luckily I made it for the skid steer and not for the RTV.
The hydraulic motor should be putting out about 32 hp and it gets stuck fairly easily. I was only able to split short wood with it too or it gets stuck. I have an oak log that is maybe 36" in diameter and probably only 4' long. It couldn't even peel a small chunk off the side without getting stuck.
It is possible that the hydraulic motor is warn out and not putting out that much HP any more but the wheel adapter for it is way too weak. I had to be really careful to not completely destroy it and only split a small pile of wood. I bent it several times and had a good 3"+ wobble in it.
I am going to have to almost completely redo it with the cone from Guru if I want it to split much wood.
Not sure yet if it will be worth the work or just start making a regular splitter.
rosewood
« Reply #20 on: July 26, 2011, 07:00:04 PM »
Rsi, do you have any type of gearbox in between hyd motor and cone . If not ,you most  likely won't ever see peak hp of motor. You will have to gear it some how.
« Reply #21 on: July 26, 2011, 07:33:08 PM »
I sized the motor to the speed I wanted. Isn't that pretty much the same difference as gearing it down?
rosewood
« Reply #22 on: August 02, 2011, 06:57:05 PM »
RSI ,what are you powering the motor with? Most skidsters with extra hydraulics are any where from 15 to 20 gpm.
« Reply #23 on: August 02, 2011, 07:00:29 PM »
It is a Gehl Skid Steer. I believe it is about 17GPM and 2750 PSI.
I calculated the motor to be about 18 CU IN.
bruey
« Reply #24 on: August 30, 2011, 07:38:04 PM »
i was reading on line and it said you cannot put the squealer on a bobcat auger attachment, they said the gear on the auger is not strong enough to turn it and it will stop,  anybody here of this, if this is true i am back to square one.
Newrichmond, Ohio
tulenutn2o
  • OWF Brand: HeatSource1
  • OWF Model: Earth Energy 190
« Reply #25 on: August 31, 2011, 06:17:37 PM »
I have one that I run off tractor pto and love it for the big logs.
bruey
« Reply #26 on: September 01, 2011, 07:04:14 PM »
i have seen those but i think my bobcat would be so much quicker but if it wont work i sure dont want to spend the money, does anyone know?
Newrichmond, Ohio
« Reply #27 on: September 01, 2011, 07:07:47 PM »
Are you wanting to use it on a post hole digger? If so, what RPM does it run?
bruey
« Reply #28 on: September 02, 2011, 04:42:49 PM »
no i would prefer to use my bobcat auger, i think it would be quicker than my tractor
Newrichmond, Ohio
tulenutn2o
« Reply #29 on: September 19, 2011, 06:29:26 PM »
I believe the cone will fit the skid loader auger shaft too. It uses a standard size auger shaft doesn't it?. If so, I think a couple hundred bucks and you're in.
Pages: 1 [2] 3
