Pages: 1 ... 10 11 [12]
Author Topic: Almost  (Read 103488 times)
tinfoilhat2020
  • OWF Brand: POS
Re: Almost
« Reply #165 on: December 03, 2017, 07:31:51 PM »
how close is richard aka slimijim? i know hes banned on here sp he cant chime in but maybe he cpuld come take a look?
Re: Almost
« Reply #166 on: December 04, 2017, 03:34:19 AM »
He is going to stop by after done installs.
Re: Almost
« Reply #167 on: December 04, 2017, 10:03:58 AM »
This is garage setup, first pic is where the Logstor enters the garage.
Re: Almost
« Reply #168 on: December 04, 2017, 02:55:19 PM »
I guess circulating water creates heat, house returns hotter than supply. :bash: :bash: :bash:
woodman
  • OWF Brand: hawken
  • OWF Model: he1000
Re: Almost
« Reply #169 on: December 08, 2017, 05:44:33 AM »
I have not really been following this thread so I don't know all the details of the problem, but it sounds like you are not happy with the wood consumption of your system and are trying to figure out where all the btu's are going, correct? I also am not sure if this has been suggested yet, sorry if it has. What I did was isolate my underground pipe where it enters the house. It takes 3 valves and 1 loop, similar to the bypass of a water softener. Then get a 5 gallon bucket and pull the return pipe off the owb and catch the water for 20 seconds. Measure and multiply by 3, you now know your gpm through just the underground pipe. Build a small fire to get your boiler up to high set point then turn off the fan, noting what time it is. Let the circulator loop through only the boiler and underground line, the longer the better but at least 4 hours. At that point check the water temp at boiler and figure btu loss. It is a pain in the neck but it will tell you if there is a problem with the underground line set. No more guessing.
Re: Almost
« Reply #170 on: December 08, 2017, 08:16:15 AM »
I used honeywell gauges in the basement setup, I had the same thing, I contributed it to my superior design and craftsmanship.  ;D
« Last Edit: December 08, 2017, 09:01:40 PM by mlappin »
shepherd boy
Re: Almost
« Reply #171 on: December 08, 2017, 03:15:14 PM »
 Ran into the same thing on a stove in Pa. that my son-in- law did a service call on. Return temp gauge was higher than feed (amongst other whacky things). Didn't ask what brand it was.
 I guess you could switch gauges and then brag on how well your furnace runs with a big delta.
« Last Edit: December 08, 2017, 03:46:52 PM by shepherd boy »
Let the youngin's have it
 Gettin' old and lazy
Smokeless
  • OWF Brand: HeatMaster ss.
  • OWF Model: G-100, 200,400
    • PCWoodBoilerSystems
Re: Almost
« Reply #172 on: December 22, 2017, 08:02:55 PM »
Hello Coolidge
   Was slim Jim able to come out to your place and figure anything out for you?
   It sounds like something is running backwards flow. from the looks of the temp readings. The Logstor has a red marker on the hot supply to house or garage. Then a plain white pipe on the returns to the boiler. It would be worth checking this out. Also make sure the Circs are going in the directions intended.
 Do you have drainage under the slab ? And could the drain be plugged if a daylight drain.
   If plugged , Is the slab losing heat Threw moisture soaked insulation?
Are you running antifreeze in systems?
Can you take a dime size piece of Logstor insulation and squeeze it flat between your fingers.
 Look threw the bottom clean out of the furnace at the bottom of the nozzle ceramic and make sure it is not broken out or away. Some cracks will occurs.
 The furnace should not be smoking, any blue or black smoke.
  How long is your water recovery taking with no heat emitters on?
Do you have thermal limiting valves on the in floor manifold?
  Sorry for your troubles and frustration. As Honda  said. I wish we were closer to come see you !!
Signature:
