Author Topic: Chainsaw oils both bar and 2cycle  (Read 37908 times)
Bluegrass Wood Burner
  • OWF Brand: Ozzark Biomass
  • OWF Model: Gasconade 500 gallon
« on: November 17, 2017, 04:40:44 PM »
In your honest opinions, is the higher priced name brand oils that much better. Especially bar oil at half the price at Rural King than major brands. Is the stihl and husky 2 cycle oils that much better?
South central Kentucky
Ford F-150
16 ft tandem trailer
3000# winch
Husqvarna 142
Husqvarna 460 rancher
6ft spud bar
Poulan 3314
22 ton lowes splitter
Timberline sharpener
"Worn out body"
Re: Chainsaw oils both bar and 2cycle
« Reply #1 on: November 17, 2017, 05:08:53 PM »
All I’ll use is Stihl bar oil and two stroke oil. Dad’s bought Tractor Supply stuff before, you could definitely tell it’s thinner.
Strangely enough, just had the woods logged, I couldn’t hardly believe it but the loggers were using old engine oil mixed with STP for bar/chain lube.
Roger2561
« Reply #2 on: November 17, 2017, 05:39:45 PM »
When I bought my Stihl MS311, if I purchased their 2-stroke engine oil the warranty on the engine went from 2 years to 4 years.  As for it being better, I have no idea and I'm not taking any chances.  Roger
CB Classic Edge 550 HD
JD LX277AWS
Stihl 021
Stihl MS 311
2012 Honda Goldwing GL1800
New Hampshire
« Reply #3 on: November 17, 2017, 05:53:09 PM »
My big saw is a Husqvarna and I have a lot of trouble with the oiler stopping up on it. You think I could poor some of the eve tone and ATF mixture in there and swish it around a little and pour it out that it would be a good way of cleaning the oil tank. Or if you have other suggestions I would sure entertain them.
Ford F-150
3000# winch
Husqvarna 142
6ft spud bar
Poulan 3314
"Worn out body"
BoilerHouse
  • OWF Brand: Home Built
« Reply #4 on: November 17, 2017, 06:51:25 PM »
I use Stihl 2 stroke oil for my 25 y.o. 032. They recommend it, so I use it.  However, I do not use Stihl bar oil. I go through a chain every couple years = 18 cords.
Muskoka, Ont
MattyNH
  • OWF Model: 7300E ; S-275
« Reply #5 on: November 17, 2017, 07:43:57 PM »
I use what what pro's use..TruSouth, Quaker State, Husqvarna..Far as the bar oil..I use what pros use as well..I also have used tractor supply and have used supertec (walmart)..For you guys that live in NH and Western Maine..Best place and priced to buy chains for all makes, bars, bar and chain oil and 2 stroke oils, anything logging is Windy Ridge Corporation in Tamworth..It where I buy all my stuff..My last chain I bought was $14 for Jonsered 2165 18 inch bar..
Crown Royal 7300E (2021)
Aqua-Therm S-275 (2006)
Jonsered 2188
Jonsered 2165
Jonsered 2050
Kubota L3800DT
Roscoe
  • OWF Brand: Hawken
  • OWF Model: HE2100
  • Southeast Michigan
« Reply #6 on: November 18, 2017, 02:39:35 AM »
For 2 cycle I primarily use MAG1 but have used others. All mixed at 4oz. oil to 1 gallon of gas. In 30 years and 5 different brands of saws Ive never blown one up or had any engine problems.
For bar oil I use Husqvarna, Stihl, or Jonsered in the summer and the cheap stuff in the winter. There is defiantly a difference.
JD 7775
Kioti DK35
Bobcat S250
All Wood Oak Series
Stihl 036pro, 362c, 064
Husk 385,570
Shindiawa 416
Griffin 14' Dump
artbaldoni
  • OWF Brand: Nature's Comfort
« Reply #7 on: November 18, 2017, 05:12:35 AM »
I use whatever 2 cycle I find on sale and have been know to mix my TSC bar oil with used motor oil. Been doing it that way for 30 years. Never had any problems.
The only time I worry about oil brand is in my wet clutch motorcycles. Nothing worse than friction modifiers on a clutch...
Nature's Comfort  NCB-175
Dolmar 5105 20"
Makita DCS6401 28"
1995 5/8 ton Dodge
7 x 14 10k Trailer
Bobcat 7753 w/EEL Tracks
22T Huskee Splitter
Fiskars X-27
Fiskars X-11
15 # Monster Maul
« Reply #8 on: November 18, 2017, 09:03:23 AM »
Roscoe do you feel the cheap bar oil flows better in cold temps? Is that why the switch up? I use the stihl oil blue and red. One in winter the other in the summer. I been working on the big saw this morning and found the hole in the bar that lets oil get to the chain was stopped up with something. Never did figure out what it was and it wasn't easy to get cleaned out. Finally blew out with air compressor after soaking in penetrating oil for a while and using small nails and wires to poke at it. Oiling perfect now.
Ford F-150
3000# winch
Husqvarna 142
6ft spud bar
Poulan 3314
"Worn out body"
wreckit87
  • OWF Model: C375
« Reply #9 on: November 18, 2017, 09:28:42 AM »
Always use Stihl 2 stroke oil. In talking to the local Stihl dealer, I was informed that 95% of the burned engines that come through his shop were using something other than Stihl oil. As far as bar oil, I use whatever is cheap. Never had any issues except for the Fleet Farm brand whatever it's called, that crap was like water
« Reply #10 on: November 18, 2017, 12:37:46 PM »
I've got a stihl 390 that's not oiling. Blew it out with air. The plastic screw that runs the oiler looks OK... I'm stumped.
benp
  • OWF Model: Edge 750
« Reply #11 on: November 18, 2017, 02:40:05 PM »
I primarily run Save a Chain 30wt bar oil all year. Sometimes Cenex bar oil when I can get it. I really like that stuff.
Saw gas is Amsoil Sabre 32/1 in 110 race fuel because all of the saws except 1 are far from stock. The 510 Dolmar (stock) eats anything.
« Last Edit: November 18, 2017, 02:52:49 PM by benp »
benp
« Reply #12 on: November 18, 2017, 02:45:28 PM »
I would check that filter on the end of the hose in the oil tank then take the bar off and make sure the driver groove and oiler orifice are spic and span.
Then next culprit to me would be actual oiler assembly itself.
Roscoe
  • OWF Brand: Hawken
  • OWF Model: HE2100
« Reply #13 on: November 18, 2017, 03:14:36 PM »
Yeah you are correct Bluegrass. Primarily for start up in cold weather. After the power head gets hot you can run the good stuff
Is this a thread about oil choices or saw repair????????
JD 7775
Kioti DK35
Bobcat S250
All Wood Oak Series
Husk 385,570
Shindiawa 416
Griffin 14' Dump
« Reply #14 on: November 18, 2017, 04:53:03 PM »
Guess I'm to blame for that. My last message I talked about using the stihl oil and then I talked about how my bar was gummed up. Guess the two go together in that respect. That lets me know the other post on here that said he uses the cheap stuff and has been for 30 years without any problems is giving me options on my bar oil.
Ford F-150
3000# winch
Husqvarna 142
6ft spud bar
Poulan 3314
"Worn out body"
