Author Topic: Pumps  (Read 14055 times)
Re: Pumps
« Reply #1 on: November 26, 2017, 08:32:32 AM »
Unless I’m mistaken sounds like  a Grundfos Alpha, if I had a choice between the two and they both did the same thing, it wouldn’t be a Taco
Re: Pumps
« Reply #2 on: November 26, 2017, 08:43:07 AM »
I have not tried them. Have been having good luck so far with the Armstong 20-20CI.
wreckit87
Re: Pumps
« Reply #3 on: November 26, 2017, 10:43:17 AM »
They do appear quite similar in application to an Alpha 1. I will second the statement above; even if prices were the same I'd still pick a Grundfos over a Taco anyday. Plus these are out of stock as well as $50 more than an Alpha. Just my opinion though
Re: Pumps
« Reply #4 on: November 26, 2017, 02:04:42 PM »
Will do some research on the Alphas and Armstrongs, trying to cut electric usage and have 6 Tacos and 1 Grundfos.
Re: Pumps
« Reply #5 on: November 26, 2017, 03:11:54 PM »
What size pumps do you have?
Re: Pumps
« Reply #6 on: November 26, 2017, 04:51:22 PM »
House primary is 016, with 4 07 on zones.
Garage primary is 010 with Grunfos 15-42 zone.
Re: Pumps
« Reply #7 on: November 26, 2017, 05:08:58 PM »
0016?
Re: Pumps
« Reply #8 on: November 26, 2017, 05:47:00 PM »
Yup
Re: Pumps
« Reply #9 on: November 26, 2017, 06:15:24 PM »
I have never heard of that model and Google finds nothing but food when I search for that.
Re: Pumps
« Reply #10 on: November 26, 2017, 06:16:50 PM »
I'm sure not up on all the pumps available and what it costs to run them, but still unsure why tacos are getting a bad rap? my taco 0011 has been pumping water for me 250 feet one way since 2003. shut it off in April and turn it on in October. every year now for a while I been thinking, this is the year it don't start, 14 years and counting. I will likely replace it with a grundfos just because there is a dealer of these pumps very close to me but if he sold tacos I would likely try another one.
Re: Pumps
« Reply #11 on: November 26, 2017, 07:00:54 PM »
Good food anyway, I will check on the pump
Re: Pumps
« Reply #12 on: November 26, 2017, 07:02:57 PM »
Don't mind the Taco, just looking to see if there is anything more electrical efficient.
wreckit87
Re: Pumps
« Reply #13 on: November 26, 2017, 07:32:25 PM »
Nothing wrong with a Taco, there are a lot of guys having great luck with them. As a person who used to sell and install Taco exclusively however, I can say that I won't ever buy another green one. In my 11 years in this game with the last 5 being exclusively red, I have only seen 1 Grundfos fail and that failure was due to the homeowner closing the isolation valve and cavitating it to death. Taco on the other hand, I could fill a dumptruck with the amount of shredded impellers I've thrown away. A customer of mine had been burning 2 or 3 Taco 007s a year for at least 5 years on his shop loop and last winter I finally convinced him to put a B&G on it because it was all I had in stock at 2am, and first fire this fall he called and wanted another because his 009 on the house loop was stuck. It was new in February of last year. Not sure what it is with them, but some people just have terrible luck with them. Can't say I've ever seen a B&G have issues, but I prefer the Grundfos as the amp draw is lower and they employ a bleeder for purging air
schoppy
Re: Pumps
« Reply #14 on: November 26, 2017, 10:21:53 PM »
I started with 4 B&G pumps on my system and have replaced 2 of them with the Grundfos Alphas. No problems with the B&G pumps just wanting to save electricity and boy do they. The Alphas also have better rated performance than the Tacos.
I used a wattmeter to test the power consumption on my B&G's on low speed (which is what I was using them on) even though it is listed on the pump and it came in very close to listed wattage. Same went for the Alpha even though it displays the power use instantly.
I was able to use the Alpha on my in floor system in my shed and for the in floor storage reservoir in my home. I had to stay with the B&G pumps on the back of my G200 for adequate GPM flow. I wish they made an economical ECM pump that had the performance of my B&G NRF-36 because these are the pumps I have to run 24/7. I tried them for my OWB pumps doing a flow test and even on low the B&G had higher GPM flow.
My power consumption on the B&G's on low was very close to 90 watts. My Alpha pump in the house is on low and it uses about 7 watts. If I remember correctly my shed Alpha is on medium and draws around 30 watts. I have had no problems with any of my pumps, knock on wood.
Husqvarna 562XP
Echo CS-361P
Echo CS-310
31 ton splitter
