Author Topic: Concrete Slab Inlet and outlet temps  (Read 26912 times)
slimchance
  • OWF Model: H2
Re: Concrete Slab Inlet and outlet temps
« Reply #15 on: December 12, 2018, 02:49:05 PM »
Speed your water up to close that delta-t ! ......and don't be running full on hot water thur that concrete floor !
I currently have the supply water temp to 100, and thought about going down to around 95 or so.  At the 100 degree supply water, I am getting right at 80 degree return water.  The pump speed is something I have not thought about too much and have not had time to experiment with.  The pump is a 15-58 that I am running on medium speed.  I started with medium and have never changed it from there.  I read a lot about higher speeds being the cause of cavitation, maybe that is why I have stayed from high.  I never really had an explanation on the advantages/disadvantages of pump speed....I'm all ears!   :)
wreckit87
« Reply #16 on: December 12, 2018, 05:27:57 PM »
Speeding the pump up on your floor is going to do nothing besides raise your electric bill
slimchance
  • OWF Model: H2
« Reply #17 on: December 13, 2018, 07:14:56 AM »
Thanks wreckit87!   That being said, do you like medium or low in my application?  On the medium setting all circuits are moving about .6 GPM.  I really don't know what the GPM's are on the low setting, I can switch it and see.
wreckit87
« Reply #18 on: December 13, 2018, 04:49:15 PM »
Those flowmeters aren't always accurate, but .6 is about max flow for a 300ft loop of 1/2". At that rate, you've got about 7 feet of head to overcome which is just out of range for speed 1. You could drop to speed 1 and slow the flow a bit while still probably maintaining temp, but it'll broaden your delta T and isn't really worth it unless that 50 cents a month is a big deal to you. I'd leave it on 2 personally
