Pages: 1 [2] 3
Author Topic: Flat plate and sidearm water heater heat exchangers  (Read 112778 times)
Re: Flat plate and sidearm water heater heat exchangers
« Reply #15 on: January 24, 2020, 10:32:03 AM »
Nope, still here in the mountains of WV.  It's been about 6 years since you dropped off the pipe.  When I move to the farm, it's just on the other side of the mountain so I'm not going too far.
Badger Pipe 30 plate - $135.  I'll get that one.  Thanks  :thumbup:
https://badger-pipe.com/products/30-plate-water-to-water-brazed-plate-1-fpt-ports-w-new-style-brackets?variant=29491365201
« Reply #16 on: January 24, 2020, 11:03:04 AM »
I would like to vacation in that area once, meet the locals, learn how to make good shine.
« Reply #17 on: January 24, 2020, 01:20:52 PM »
Well, when I finally do move to the farm, I'm going to need some Logstor again...
« Reply #18 on: January 24, 2020, 02:44:44 PM »
Can you make shine?
« Reply #19 on: January 24, 2020, 07:31:13 PM »
I have never tried to.  It is legal to do (for fuel).  I have a friend that makes fuel and stores it in mason jars, though.
« Reply #20 on: January 25, 2020, 03:47:12 AM »
Maybe when I come down we can visit your friend as well?
« Reply #21 on: January 28, 2020, 07:02:41 PM »
Do I need a monoflow tee or will a pair of normal tee's work?  I'm obviously going to install isolation valves for the flat plate.
« Reply #22 on: January 29, 2020, 07:10:08 PM »
I've ordered the flat plate, I need to still order the 1" pex parts to make this work for me.  Regular tee's?
« Reply #23 on: January 30, 2020, 01:29:41 AM »
I use mono flo tees but if you space regulars away from each other to promote flow, they will work.
« Reply #24 on: January 30, 2020, 05:01:08 AM »
Or just send it all through if it's large enough.
« Reply #25 on: January 30, 2020, 06:46:55 AM »
« Reply #26 on: January 30, 2020, 05:12:09 PM »
That should be no problem putting in series. 30 plates have almost no head pressure drop. 20 plates are usually fine in series unless there are a lot of other restrictions in the system.  All the plates are in parallel so the more you have the less restriction you get.
If you had used a 10 plate then the monoflow tees would be needed or a much larger pump.
The size of the ports on a plate exchanger are usually not a bottleneck. Even 3/4" would not be a restriction unless you have full 1" iD or larger piping.
« Reply #27 on: January 31, 2020, 06:27:40 AM »
Years ago I researched pressure drop on flat plates, and I would agree with RSI. I've used hundreds of 3x8 30 plate heat exchangers on systems requiring medium to lower flow rates/ smaller pumps and they've worked fine.
« Reply #28 on: January 31, 2020, 06:35:08 AM »
That's the way I'll do it, then.
wreckit87
« Reply #29 on: January 31, 2020, 04:29:39 PM »
The pressure drop across a 3x8 30 plate is 17 feet of head at 7 GPM versus a 20 plate 5x12 with 2 feet of head at the same flow rate. A 3x8 will destroy the flow rate in any system if piped in series, and unless you're living in a doghouse you'll need more than 2 GPM. The extra $30 you spend on a 5x12 will be recovered in 2 months of electrical usage by using a smaller pump
Pages: 1 [2] 3
