Outdoor Wood Furnace Info
News
Home
Help
Search
Login
Register
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
Username:
Password:
General
DIY remodeling with Hydronics
Copper tubing for wall heat?
« previous
next »
Pages:
1
2
3
Print
Author
Topic: Copper tubing for wall heat? (Read 75458 times)
Fabricator Extraordinaire
Global Moderator
Hero Member
Offline
OWF Brand: homebuilt, now HeatmasterSS
OWF Model: Martin Steel Works Gen 1 then, now a G200.
North Liberty, Indiana
Re: Copper tubing for wall heat?
Reply #30 on:
March 15, 2020, 08:22:10 PM »
You can definitely feel the heat coming out, like 116-118 degrees out of each one. Much to my wife’s horror there was a cobweb above the one you could visibly see getting moved around when it was on.
Once I have the Mac back up and running I’ll post some pictures, trying to do it from my smart phone is a bad joke at best.
Global Moderator
Hero Member
Offline
Reply #31 on:
March 31, 2020, 08:42:59 PM »
Middle stud bay, only one that came close to a standard width, at one time there was a door in two different spots in that wall. Placed a piece of lathe between the pex and the foil insulation as it was heating the wall up pretty good on the bedroom side. Wasn’t sure if it would cause issues with the drywall later.
Wall heat on the Cheap
by
Marty Lappin
, on Flickr
One of the narrow ones, still managed to get at least 75’ of pipe in it, just kept the coils closer together.
by
Marty Lappin
, on Flickr
First one I did, have a 4”x10” register top and bottom on the bedroom side of the wall. Used a piece of insulation board caulked in place top and bottom to seal the stud bay off.
by
Marty Lappin
, on Flickr
Irwin 1” speed bit with a 10-12” extension was just barely long enough to get thru the beam into the basement.
by
Marty Lappin
, on Flickr
Those speed bits just eat batteries once they grab hold.
by
Marty Lappin
, on Flickr
Global Moderator
Hero Member
Offline
Reply #32 on:
March 31, 2020, 08:55:20 PM »
Stripped the lathe and plaster on the walls then just the plaster on the ceiling as it had 6” of blown in above it. Screwed strips of 1/2” plywood to the ceiling joists to keep the lathe tight and act as a spacer, then added a 1” foil faced polystyrene insulation board, then screwed 2x4’s over the insulation and fastened the drywall to that so ended up with a double dead airspace to add to the insulation value.
by
Marty Lappin
, on Flickr
Picture of the temps partway thru a heating cycle. Diminishing returns seem to add up faster with this than say baseboard. 64 to 70 is pretty fast actually, little more than an hour on a room thats a little under 12’ x 15’, out of curiosity once its over 73 it takes a LONG time to keep gaining any, might take as long to gain another degree once its over 73 as it did to get it from 64 to 70.
by
Marty Lappin
, on Flickr
by
Marty Lappin
, on Flickr
Hero Member
Offline
OWF Brand: HeatMaster
OWF Model: GS 100
Reply #33 on:
April 01, 2020, 04:47:49 AM »
Im getting ready to start a similar project this summer if it slows down enough. I'll post some pictures when I get done. Have a room with a cast iron rad, but would like the wall space, so I'm thinking radiant wall. Floor is concrete so no radiant there.
Thanks for the pictures!
www.heatmasterfurnace.com
Print
Pages:
1
2
3
« previous
next »
General
