Author Topic: Brass fittings  (Read 23466 times)
timothy4140
  • OWF Model: BL 34-44
Brass fittings
« on: December 26, 2020, 09:19:22 PM »
This past week I had my second fitting on my heat exchanger developed a leak, when changed it was paper thin as if it was sand blasted...
This is second time, first year or so ago, different heat exchanger...
Thoughts???
Tim C
Winchester, Virginia
Ford F350
Kubota RTV
New Holland TA95
Re: Brass fittings
« Reply #1 on: December 27, 2020, 08:52:08 PM »
Something with the water, boiler side or domestic or both? Maybe try dielectric unions?
Re: Brass fittings
« Reply #2 on: December 27, 2020, 10:25:36 PM »
What kind of fittings are these? Is your pump way oversized?
I would collect a sample in a clear jar and let it settle and see if there is much sediment in it. if there is then I would install a filter.
If you haven't had the water tested recently, I would look into getting that done.
Re: Brass fittings
« Reply #3 on: December 28, 2020, 04:17:36 AM »
Were these fittings on the domestic side or boiler side?
I saw a HeatMaster unit with various fittings honeycombed thin recently. Turns out they were using some odd powdered water treatment. I think electrolysis was doing its thing.
Re: Brass fittings
« Reply #4 on: December 28, 2020, 09:11:30 AM »
Much like in a diesel I imagine. I have a sleeve out of a Waukesha that had numerous pits around the bottom ring and one made it clear thru the liner eventually.
Radio Tech1964
  • OWF Brand: Hawken Energy
  • OWF Model: HE-1100
  • Stihl MS 250 John Deere CS 36 2013
    • Weather Info
Re: Brass fittings
« Reply #5 on: December 29, 2020, 10:17:16 PM »
This brought up a good question for me..Did I ground the boiler when I reinstalled it  ::)
Better check that tomorrow that would go some ways to reducing the effects of electrolysis.
I was half frozen to death when I installed this time and I have never even looked at grounding since. :D
