Author Topic: The green living-through your energy saving home devices  (Read 4633 times)
westcanadian01
« on: July 18, 2011, 02:09:16 AM »
hi there,
Home insulation is an effective home improvement that helps save energy. Most of the houses heat passes through the walls or loft. It is worth checking if your home is properly insulated.
Around cavity insulation
This insulation helps you save up third of the total heat of your home. Cavity wall helps your home maintain proper heat temperature. When you use less energy it means less carbon dioxide is emitted. You’re not only having a well-rounded home but you also able to help keep the earth a place for healthy and safe living.
hope this can help
Youtube video removed by Ridgekid (Spam)
« Last Edit: August 09, 2011, 11:21:04 PM by Ridgekid »
