Pages: 1 2 3 [4] 5 6
Author Topic: Webcam link  (Read 44096 times)
Re: Webcam link
« Reply #45 on: September 22, 2011, 05:52:15 PM »
Does your modem happen to be acting as a router? If so that might be your problem. Did your router change the IP address of your router to that from the default?
Ridgekid
Re: Webcam link
« Reply #46 on: September 22, 2011, 06:08:20 PM »
It goes from modem to router to swtiches to components of my LAN. When I changed my LAN from Dynamic 192.168.100.5 to Static 192.168.100.150 nothing changed. So I changed it back.
The modem has a external IP address (74.98.xx.xx) that never changed no matter what I did to my Router.
I don't know how things work upstream of the modem, but when I did a location check on the modem it said I was in Virginia!
Sorry I'm not more informative, thought this was a easy set-up.
I just tested the webpage (internal LAN) and the webpage I wanted to share popped right up. http://192.168.100.5/default.htm
Re: Webcam link
« Reply #47 on: September 22, 2011, 06:13:30 PM »
If you log into your router can you find what it is showing for the WAN IP? Is it the 74.... IP or a 192?
Re: Webcam link
« Reply #48 on: September 22, 2011, 06:34:56 PM »
Ok, I just did a quick search and it appears that the modem is set to router mode by default. You have to log into the modem and either configure it so it is not running it router mode or forward the ports from there to your router.
http://www.webhostingtalk.com/showthread.php?t=730063
Ridgekid
Re: Webcam link
« Reply #49 on: September 22, 2011, 09:26:32 PM »
Wan page is not setup. Intructions on how to are as follows:
WAN Setup Help
Using this page, you can set up a Default DMZ Server and allow the router to respond to a 'ping' from the internet. Both of these options have security issues, so use them carefully.
Disable SPI Firewall - The SPI (Stateful Packet Inpection) Firewall protects your LAN against Denial of Service attacks. This should only be disabled in special circumstances.
Default DMZ Server
Specifying a Default DMZ Server allows you to set up a computer or server that is available to anyone on the Internet for services that you haven't defined. There are security issues with doing this, so only do this if you're willing to risk open access. If you do not assign a Default DMZ Server, the router discards any incoming service requests which are undefined.
To assign a computer or server to be a DMZ server:
Click the Default DMZ Server check box.
Type the IP address for that server.
Click Apply.
Respond To Ping On Internet Port
If you want the Router to respond to a 'Ping' from the Internet, click this check box. This can be used as a diagnostic tool. Again, like the DMZ server, this can be a security problem. You shouldn't check this box unless you have a specific reason to do so.
MTU Size
The normal MTU (Maximum Transmit Unit) value for most Ethernet networks is 1500 Bytes, 1492 Bytes for PPPoE connections, or 1436 for PPTP connections. For some ISPs you may need to reduce the MTU. But this is rarely required, and should not be done unless you are sure it is necessary for your ISP connection.
NAT Filtering
This option determines how the router deals with inbound traffic. The Secured option provides a secured firewall to protect the PCs on LAN from attacks from the Internet, but it may cause some Internet games, point-to-point applications, or multimedia applications not to work. The Open option, on the other hand, provides a much less secured firewall, while it allows almost all Internet applications to work.
Disable SIP ALG
Some SIP applications have their own way to work around the NAT firewall issue, and the SIP ALG would conflict with those solutions. In most cases, you do not have to disable the SIP ALG. However, if your SIP applications cannot work with the router, you can disable the SIP ALG and try the applications again.
Ridgekid
Re: Webcam link
« Reply #50 on: September 22, 2011, 09:43:02 PM »
For more info:
I have this modem: http://compare.ebay.com/like/160646497243
If I type in the IP address 74.98.xx.xx it asks for a user name and password which I don't have
There is a MAC address on the bottom of the unit tho!
Re: Webcam link
« Reply #51 on: September 22, 2011, 10:19:15 PM »
what happens if you try going to 192.168.1.1
That should be the IP of your modem. For the login, try:
user id: your verizon.net user id
password: your verizon.net password
If that doesn't work try :
username: admin
password: password
Ridgekid
Re: Webcam link
« Reply #52 on: September 22, 2011, 10:29:49 PM »
I got into it once. It was admin/password.
Firmware is ver 5.01.00.04  Wanted to find a update, if there is one.
No firewall installed
Fixed the clock/daylight savings time
Checked the upnp box so it would show up on LAN. I know what IP address they use for router. 192.168.100.xx
Got the mac address
Am I getting closer?
Re: Webcam link
« Reply #53 on: September 22, 2011, 10:50:25 PM »
I am getting tired   lol
The last link might not have been any good. I went back and see it says the menus are different for your model.
I just found this which might work. http://www.dslreports.com/forum/remark,17002322
I am not sure if you need to put in the IP of the router or the webcam. I am thinking it needs to be the router because you have to get through that firewall but if it doesn't work you could try the other.
Ridgekid
Re: Webcam link
« Reply #54 on: September 23, 2011, 06:34:44 AM »
I was getting tired too. Went to bed way too late! (or should I say early- 2am)
At least we did find out we had access to the modem! If your interestd in providing me some Tech Support, PM me your phone number and a good time to call you. It might go faster than sending recommendations on this board.
Ridgekid
Re: Webcam link
« Reply #55 on: September 23, 2011, 01:03:37 PM »
No. I tried with errors. I once comitted my modem to DMZ. Don't know what it was but tried it. Oops it didn't like that all all!  Luckily there was a reset on the modem to put it all back to default.
I need my Modem and router to start agreeing what I want. My camera software (Blue iris) is a webserver based software. It prefers port 80 but can be set sequentually <sp?> moved up if needed. It needs to tell the router it's ok if mr modem comes in and see the Blue Iris webcams.
In other words: My modem has a external IP adress XX.XXX.XXX.XX and it communicates with IP adress 192.168.100.39 which is my router.  So how do I tell my router if anyone pings my Ext IP adress to forward to my router and my router should forward to my webserver? (which is my computer)
I'm not having any trouble posting pics to my weather station website. <click weblink under my user name
Anyway, I'm not smart enough to know what it all means. Two many abbreviations. Looking for professional help! Any volunteers?   ;)
Ridgekid
Re: Webcam link
« Reply #56 on: September 23, 2011, 06:28:07 PM »
Well at least I can say I acomplished something this week concerning the webcam. I installed the dusk to dawn light!
<click web link under user name!
Ridgekid
Re: Webcam link
« Reply #57 on: September 25, 2011, 02:09:50 AM »
I'm bridged and have a port forward. (crossing fingers)
www.ridgekid.dyndns.com:81
« Last Edit: September 25, 2011, 02:19:54 AM by Ridgekid »
Re: Webcam link
« Reply #58 on: September 25, 2011, 06:22:18 AM »
no luck Ridge
Ridgekid
Re: Webcam link
« Reply #59 on: September 25, 2011, 06:39:01 AM »
wow.... very disappointed. Maybe I don't have the dyndns set-up right.....
www.ridgekid.dyndns.org
