Pages: 1 ... 4 5 [6]
Author Topic: Webcam link  (Read 44097 times)
fireboss
Re: Webcam link
« Reply #75 on: October 08, 2011, 06:20:17 AM »
when i click on ur web cam icon it takes me rite to your web cam it has the date and time stamp on it and its always right. am i missing something else?
Ridgekid
Re: Webcam link
« Reply #76 on: October 08, 2011, 07:19:01 AM »
fireboss- No that works the way I set it up. Those are snapshots uploaded to my weather station. No issues there.
 I want to get my cameras to go "LIVE" using Blue Iris software. Blue Iris has a built in web server. I want to use a dyndns address to link a connection to this program. (Dyndns hides IP address')
Here's a link to someone that has succeeded setting theirs up: http://www.acmecombustion.com/jpegpush.htm
Ridgekid
Re: Webcam link
« Reply #77 on: October 08, 2011, 11:38:17 AM »
Reset EVERYTHING- Modem and Router!
Modem is Bridged -PPoE provider
Router reset-Reattached all devices (one at a time) DHCP network
Router has Port forward set to 80-81
Router has Enabled dynamic DNS to ridgekid.dyndns.org??
Using DYN client to auto update external IP address to Ridgekid.dyndns.org
Can anyone think of anything I'm missing?
www.ridgekid.dyndns.org
Re: Webcam link
« Reply #78 on: October 08, 2011, 12:35:12 PM »
Hard to say without being there.
There are two ways I would go at it at this point. Either reset the modem to the way it was and find the WAN IP address of the router and set DMZ to that address. Then set port forwarding in the router.
Or
I would try resetting the modem back to the way it started and replace the router with a switch.
Everything on the network will have to get new IP addresses after that. If set to DHCP just resetting it will get a new IP. If set to fixed you will need to change manually. Doing this would set all the IP addresses on your network to 192.168.1.xxx
After you get new IPs then log into the router and setup port forwarding for the camera.
Ridgekid
Re: Webcam link
« Reply #79 on: October 08, 2011, 01:38:06 PM »
Question: What about QoS and Static route? Should I have something set-up there?
Re: Webcam link
« Reply #80 on: October 08, 2011, 01:43:18 PM »
I don't think you want to enter anything for them.
Ridgekid
Re: Webcam link
« Reply #81 on: October 08, 2011, 01:51:57 PM »
How about another port? 8080?
www.ridgekid.dyndns.org:8080
Re: Webcam link
« Reply #82 on: October 08, 2011, 02:01:39 PM »
Getting close. I would check the dyndns account and see if you can manually update the IP address.
Ridgekid
Re: Webcam link
« Reply #83 on: October 08, 2011, 02:10:32 PM »
I'm using the dyn updater. Anytime my IP address changes it changes it at the dyn website (host?)
Ridgekid
Re: Webcam link
« Reply #84 on: October 08, 2011, 02:22:32 PM »
I think I got it! Drop the WWW!
http://ridgekid.dyndns.org:8080
If that link works, I want to try to go back to port 80. then we can drop the 8080 at the end of the current address.
« Last Edit: October 08, 2011, 02:31:23 PM by Ridgekid »
Ridgekid
Re: Webcam link
« Reply #85 on: October 08, 2011, 02:42:16 PM »
Test without port 8080
user:guest
password:guest
Note: I will change the password and user name before the end of the weekend. But it won't be public when I do. Just PM me if you want to have access.
« Last Edit: October 08, 2011, 02:45:58 PM by Ridgekid »
Re: Webcam link
« Reply #86 on: October 08, 2011, 09:03:10 PM »
I connected, it says the server may be down but it shows your front and back cameras.
Ridgekid
Re: Webcam link
« Reply #87 on: October 09, 2011, 12:22:27 AM »
Not sure why you got that message. Server wasn't down. Any other issues?
NOTES-
As you open the page you have choices at the top for JAVA, JPEG or Active X. When I had IE I enabled Active X, now that I have Mozilla it's JPEG. So I'm guessing browsers determine how you will view it.
Anyone have a speed problem? Don't look like I'll be able to go any faster. I checked and I'm set to maximum MTU.
Now that the cameras can go live I look forward to sharing my Green Dragon puffing away.......
EDIT: for those using active X I raised the bitrate from 512 kbps (default) to 900 kbps
« Last Edit: October 09, 2011, 09:09:29 AM by Ridgekid »
Ridgekid
Re: Webcam link
« Reply #88 on: October 09, 2011, 10:05:46 AM »
Sorry all. I removed the user guest. If you want to view email or pm me and I'll set you up.
R W Ohio
Re: Webcam link
« Reply #89 on: November 16, 2011, 06:22:19 AM »
Ridgekid,
It looks a little foggy in your web cam photos this morning.
R W Ohio
Canal Fulton,Oh.
