Author Topic: Ml 30 boil over  (Read 11385 times)
Firechaser
Ml 30 boil over
« on: September 29, 2011, 02:30:17 PM »
Help I can't figure this one. I fill the boiler until its barely reading add but then when I heat it overflows. When it cools its way down again. Do I only use the gauge when hot?
Tony
ML30
Husky 455
fireboss
  • OWF Brand: central boiler
  • OWF Model: 6048
Re: Ml 30 boil over
« Reply #1 on: September 29, 2011, 02:35:21 PM »
there is something  probly wrong with your gauge!
Re: Ml 30 boil over
« Reply #2 on: September 29, 2011, 04:15:22 PM »
I would just fill it, let it overflow. Then when it cools off just remember where it is and use that as the cold full mark. Water expands quite a bit and you can't have it right both hot and cold.
martyinmi
  • OWF Model: Optimizer 250
Re: Ml 30 boil over
« Reply #3 on: September 29, 2011, 04:23:04 PM »
You are doing it right Tony. Our Optimizer 250's do the exact same thing. Once you get it up to 175* or so then adjust your fill. If it did not come preset that high, I'd move it up if I were you(175* off). My Empyre 100 does the same thing.
Are you pretty happy with your P&M so far?
Newholland TZ-25da
30+ Chain Saws
'05 Dodge Diesel
Michigander
TSC 35 Ton Splitter
oldchenowth
  • Guest
Re: Ml 30 boil over
« Reply #4 on: September 29, 2011, 06:03:37 PM »
Wood Doctor freaked me out the first time too.  I let her get to temp and then adjusted my happy medium mark.  Had a regular fountain when it was coming up to temp.  Now it runs like a champ, guess I was unprepared for exactly how much expansion really took place.
Firechaser
Re: Ml 30 boil over
« Reply #5 on: September 29, 2011, 06:21:18 PM »
Ok thanks all. I am very happy with my P&M so far but I haven't been through a winter yet. It looks well built.
Tony
ML30
Husky 455
Re: Ml 30 boil over
« Reply #6 on: September 29, 2011, 06:32:08 PM »
200 gallons of water at 55 degrees F and heated to 180 F will increase in volume by about 5 1/4 gallons
Bull
  • OWF Model: Rebuilt H2
Re: Ml 30 boil over
« Reply #7 on: September 30, 2011, 06:40:53 AM »
WOW I didn't realize that water expanded that much.
Southern Indiana
Airgap
Re: Ml 30 boil over
« Reply #8 on: October 05, 2011, 07:56:18 AM »
I've seen water heaters where people have plugged a dripping relief valve, swell up on the ends like a balloon.
There's a reason for reliefs, and there's a reason they drip or pop off...
