Author Topic: Converting tractor log splitter for use with PTO driven pump  (Read 8653 times)
arkgac5
« on: October 13, 2011, 07:22:28 PM »
I have a tractor 3pt mount log splitter that I want to convert to use with a pto driven hyd pump. I plan to use it on a Ford 8N. This tractor does not have the live hydrolics that my Massey Ferguson had. The ferguson gave out, so onto a new plan.
I have found several PTO driven pumps at Northern Tool. One is linked here.
http://www.northerntool.com/shop/tools/product_200329702_200329702
I would also need a tank to go with the pump for the fluid. Link here for a 12 gal.
http://www.northerntool.com/shop/tools/product_200466866_200466866
Has any one here attempted and succeeded in converting a log splitter from internal tractor hydrolics to external hydrolics? Is this pump adequate? Should I step up to the 21 gpm unit?
Or just forget it, selling my 3 pt and buying a gas engine unit.
Thanks
2007 Shaver 165
Near Harrison, AR
BoilerHouse
  • OWF Brand: Home Built
Re: Converting tractor log splitter for use with PTO driven pump
« Reply #1 on: October 13, 2011, 08:39:08 PM »
I think it is fairly common to have PTO driven pumps for log splitters.  I see on the link that you supplied with the pump that in the comments section a gentlemen used that pump for his log spliter powered by his 8N and apears happy with it.  Don't forget a filter with yout tank.
All that being said I prefer a stand alone log splitter as it frees up my tractor to move logs and blocks around when necessary.
Muskoka, Ont
